Im done.,. Cant make the condenser!
Posted: Fri Jul 01, 2005 8:36 pm
by Guest
Well i tried 4 times using all the hints i received and I cant make the damn thing. I even heated it red hot but the salt inside solidified and i cldnt get the water to run thru it..Plus it was pinched too.
Can anyone make me one to fit a 2" diam Cu pipe 1 foot long?
Blueraven
Building
Posted: Fri Jul 01, 2005 8:48 pm
by Gypsy Davey
I am willing to try. What size tubing are you using and where can I get more size and construction details.
BTW- I tried to get tight bends in 7/16" copper and it was a total failure. I went to 3/8" and it bent like a dream. Can you use a smaller dia. condenser tubing?
BTW- I am in the States for shipping purposes.
Dave
Posted: Sat Jul 02, 2005 12:38 am
by Blueraven
ITs 1/4" OD.
http://i17.photobucket.com/albums/b79/R ... neEL-2.jpg" onclick="window.open(this.href);return false;" rel="nofollow
http://i17.photobucket.com/albums/b79/R ... sorcap.jpg" onclick="window.open(this.href);return false;" rel="nofollow
Mack. it seemed the salt was coming out but very slowely.. I just got pissed.
It had some kinks near the top so i cut them out.
Posted: Sat Jul 02, 2005 8:36 am
by Grayson_Stewart
Blueraven,
Did I send you that pic of my condensor? I don't remember posting that one.
Just leave the water hooked to it and pointing away from your grass...it will clear the salt. Takes awhile for water to dissolve 20 feet of salt.
Posted: Sat Jul 02, 2005 9:56 am
by Guest
GS,
I thght that one lw d be sufficient.. It wasnt a dble but had over 18 turns. endedn up with several kinkes neat the end. when the saslt didint wsant to come out, i stretched it out and cut off several opieces to remove the kinks.
Maybe ill try to get the salt out again.
Posted: Sat Jul 02, 2005 9:14 pm
by Jaeger
You posted that one a while back grayson :)
You sure make some sexy coils! I love curves :D
Posted: Sun Jul 03, 2005 12:21 am
by Guest
Jeagar & gueat:
Your an idot!
Im retired!
Posted: Sun Jul 03, 2005 1:00 pm
by Brett
was that a return of a randomly insulting guest?
Posted: Sun Jul 03, 2005 2:33 pm
by Blueraven
B.
No it was me..I was frustrated abt doing the condenser and saw their, what i interperted, as totally superfluous posts and just spouted off..
Please ignore it..
Got it made..whew!
Posted: Mon Jul 04, 2005 1:47 pm
by Blueraven
Well i finally made it on the 4th try...thanks to a tip from the "still-master"".
Herer it is:
http://photobucket.com/albums/b79/Rocke ... ics003.jpg" onclick="window.open(this.href);return false;" rel="nofollow
Now onward and wobbledy upward..err...maybe downward,, <GG>
Posted: Mon Jul 04, 2005 2:44 pm
by Jaeger
Well, congrats!
What method ended up working best for you?
Posted: Mon Jul 04, 2005 3:04 pm
by Blueraven
Method:
Tape standing end to a member that is perp to the member you are coiling on. firmly but slowly wrap it ard the broom handle or whatever.
Where i messed up (I stink), particlarly when i added salt, was that i didnt reroll the pipe back to its orig coil direction..so when i started back coiling it i fig i must have started coiling it in another direction other than the orig coil
direction.
this time i didnt heat it , or use salt or anything extra..just firm constant
and slow progression of the coils.
I want to thank Alex for his expertise in this area..He's the man!
