Pressure Cooker distiller is Dangerous ???
Posted: Tue Sep 15, 2009 6:39 am
by Rafael A.
I finish my "distiller", but using a pressure cooker (4,5 L)and came one question. Top of pan lid have a little hole to do pressure on normal use (03 mm), for a distill whith 60% alcohol ,40 % water (absinthe) maybe it do a big pressure and cause a explosion or not?
For the correct use, do a largest (09 mm)hole than original (03 mm) or make much largest hole??
Re: Pressure Cooker distiller is Dangerous ???
Posted: Tue Sep 15, 2009 7:19 am
by DrTorque
I'm not completely sure what you're asking...
Do you have a lid with a 3 mm hole and a 9mm hole? Are you asking which hole you should attach the condensor to?
Posted: Tue Sep 15, 2009 7:30 am
by Dnderhead
Go with the larger hole (9mm) a still should not build up pressure.
be aware that not all pressure cookers will seal at low pressure ,a different seal mite be needed.
Posted: Tue Sep 15, 2009 8:51 am
by Rafael A.
Dnderhead wrote:Go with the larger hole (9mm) a still should not build up pressure.
Ok,i do a hole whith 1/2" for more safety. thanks!!
Posted: Tue Sep 15, 2009 8:59 am
by Rafael A.
DrTorque wrote:I'm not completely sure what you're asking...
Sorry,my english is very bad!!!
lid have a original hole with 3mm and i will use it to the thermometer and do a new hole for the steam get out and run to the condenser, this new hole i will do with 1/2".
Posted: Tue Sep 15, 2009 3:27 pm
by rad14701
I hope your pressure cooker is made from stainless steel and not aluminum because aluminum ones have been known to fail prematurely due to pitting after only a few runs...
Posted: Tue Sep 15, 2009 4:15 pm
by LWTCS
But some units are very well made and have completed many runs.
This unit is manufactured by Mirro (uhh the boiler, not the still head).
I learned a lot and now I am poised to move on.
Posted: Tue Sep 15, 2009 4:41 pm
by rad14701
Yes, not all aluminum is the same, just like other metals... Some aluminum is softer and some harder, depending on whether it is an alloy and, if so, what other components the alloy contains...
Posted: Wed Sep 16, 2009 7:25 am
by Rafael A.
LWTCS wrote:But some units are very well made and have completed many runs.
Very nice job......
My P. cooker is made in aluminiun, find made in stainless steel is very dificulty here and very expensive too.
Posted: Wed Sep 16, 2009 5:49 pm
by LWTCS
Thanks,
I hope you have good luck with your starter unit and move on to a more capable operation.
Posted: Fri Sep 18, 2009 2:14 pm
by Rafael A.
LWTCS wrote:Thanks,
Today my "distiller" work very well with only water ...but works!
Tomorrow i will do my absinthe (maybe it)
Posted: Fri Sep 18, 2009 6:18 pm
by blanikdog
Good luck, Rafael.
blanik
