Getting bowl seal right.
Jaxom
Post by Jaxom »
I think I have a good idea about how to cut out the top of my one keg and then how to set-up the cork seal and bolts, but being new at this and all, I just wanna triple check before I start cutting my keg.
1st step is to make a template by tracing the bowl. Make a smaller circle inside the trace by 1/4" to compensate for the bowl lip. Using the inner circle is what then will be transfered to the top of the keg and I'll use as guild line while cutting with my jig saw (using metal blades).
2nd step is to mount bolts. If I don't drum up enough $$$ to have someone weld these on, I'll have to drill holes and mount the bolts through the keg. The longest stainless bolts that Home Depot sells have threads the entire lenght of the bolt are only 2" long. Is this long enough?
Figuring a sandwich of washer (inside keg), washer (outside keg), nut to hold the bolt in place, then fender washer to hold down the bowl, and finally a large wing nut on top.
Spacing the bolts. Many have suggested using 8 bolts instead of only four. To be on that safe side, this is what I intend to do. But how far from the inner edge of the hole I've cut should these be placed 1/2", 3/4"? 1"?
Last step, attaching the cork seal to the bowl. Was it ever determined wiether using RTV sealant was okay or not?. I was thinking of doing a double thickness of cork, one glued to the keg and another glued to the bowl rim. Only using a thin, nearly invisble layer. (I've seen buddies go over board with this stuff on thier car engines...I'm not that sloppy).
Sidebar.... I'ld like to set my lil 1/4 barrel up as an electric pot still. That way I can work with it during the winter months. Could I get buy with a single 120v say 1800-2000watt heating element?
tia,
Jaxx
This topic has 13 more replies
Register Login
