new to forum
Posted: Sun Nov 22, 2009 4:24 pm
by nstruktr
Hello all, I am new to this. I have built a vm reflux still and ran it for the first time, with no results. The temp gauge at the take off never got to 79 degrees C. Should I reduce the flow of water to the top condenser or am I way off?
Re: new to forum
Posted: Sun Nov 22, 2009 4:42 pm
by kiwistiller
if that is the case, the liklihood is that you didn't apply enough power for long enough. what are your power inputs, and time trying?
Re: new to forum
Posted: Mon Nov 23, 2009 5:29 am
by nstruktr
I'm using a propane burner, and i ran it for 2 hours. My still is 3 inch stainless 5' long with vm head attached. It runs fine without the vm head attached. I spent a lot of time building this, I'm puzzled as to why it dosen't work. I have seen others here with the exact same setup that works. I have followed directions to a T. This is not my first attempt at distilling, just my first at trying to make a neutral spirit. Oh, my top condenser stops right at the top of the take off arm. Maybe increase the distance? Should I really increase the flame on the burner? I am using the same flame as before. (How do you post an image?)
Re: new to forum
Posted: Mon Nov 23, 2009 4:01 pm
by rad14701
Water flow is not the problem... It sounds like you aren't pushing enough heat... As the reflux condenser knocks down the rising vapor it should force some of it to redirect into the take off branch... A good rule of thumb would be to have the bottom of the condenser at least one column diameter above the take off branch... Also make sure your packing isn't too tight...
You can add a picture in the Upload attachment section immediately below the Post a reply section (where I'm typing right now)... Right below the Submit button... You have to click on Add the file after you browse for and select your image...
Re: new to forum
Posted: Tue Nov 24, 2009 4:20 am
by nstruktr
Thanks rad1470 and kiwi ! I am going to try moving my top condenser up, I'm sure I am pushing enough heat. Thank you everyone for your input. I will post some pics of my still after the holidays.
