I finally finished off the fabrication on my still. It's just a tiny one to start out with and get used to how things work and the correct fabrication techniques. 8 quart SS stock pot, 3/4 x 10" copper column out the top. 90 degree bend to 1/2" reducer. 12" horizonal run to another 90 bend and 3/8" reducer. 28" liebig condenser, 3/8 inner, 1/2 outer. I use a 5 gallon bucket and gravity to run the water throught the liebig. I have to run the water in the top and out the bottom right now because gravity isn't enough to run the water fast enough from bottom to top. Powered by a coleman propane camp stove.
I ran some water, then some water and vinegar x2 to check out for leaks. A little flour paste on the non soldered joints and around the pot lid and no more leaks. Ran a couple of bottles of cheap wine that nobody wanted to drink through as the the cleaning run. Everything seemed to work fine. I could crank up the power on the stove and the liebig seemed to knock down everything just fine. The distillate came out cool. I'd post the pics but after viewing everyone else's, I'm not too proud of my soldering and it's a little small. Far too embarrassing to do that. Will just hide in my garage with it instead...
On my first real run, I loaded up the stock post with a gallon of rum wash. Eveything went fine, and ended up with about 690 ml of output. next step figure out how to make the cuts better. I kept about 300 ml from the middle and it tastes suprisely good. need to work on figuring out the cuts now. Have a few more batches on the go.
However, to the point of my post. Even though my condenser appeared to be knocking down all of the vapour, it was making a "huffing" sound and if I looked carefully, I could occationally notice small little vapour clouds. If I placed my mouth next to the output, I could feel to the puffing on my lips as well. It was quite cold outside and I could see my breath when I breathed.
Was that alcohol vapour being pushed out from the liebig not being able to handle all the vapour? Or was I noticing air moving in and out caused by the contraction of the vapour condensing at the top of the liebig?
new still "huffing"
