condenser coil cleaning
Posted: Sun Jan 24, 2010 11:06 am
by kazanas
After 10 years of use, I would like to give my coil a perfect clean.I usually clean it with water but I think there is some smell remaining. I tried to pass an electrician spiral steel through, with a brass, but couldn't.
My coil is from ss , one inch internall diameter.
Any ideas??
Re: condenser coil cleaning
Posted: Sun Jan 24, 2010 3:16 pm
by HookLine
Dilute phosphoric acid, about 15%, should be enough. Soak overnight.
Can usually buy it from hardware stores.
Use safety glasses and gloves.
Posted: Sun Jan 24, 2010 10:17 pm
by kazanas
ok thanks.
Posted: Sun Jan 24, 2010 10:30 pm
by olddog
If you are in OZ its marketed under the "RANEX" name, and obtainable from Bunnings
Posted: Tue Jan 26, 2010 3:26 am
by kazanas
A little bit further from OZ, 30 minutes by the phone, Athens Greece.
BTW, how the name OZ, came from????
Posted: Tue Jan 26, 2010 5:44 pm
by Nightforce
If you can find it, try some TSP (tri-sodium phosphate). My local hardware store had some and it works really well for removing oils. Doesn't polish much, but certainly cleans it really well. Then a good rinse, and you've got some nice clean coils.
Posted: Tue Jan 26, 2010 5:57 pm
by blanikdog
olddog wrote:If you are in OZ its marketed under the "RANEX" name, and obtainable from Bunnings
Thanks for that, OD. On my list for the next time we visit Bunnings. My rig must be crying out for a bloody good cleaning.
blanik
