Cheapest way to aquire heating elements?
Posted: Mon Mar 01, 2010 4:04 pm
by dStill
can i use heating elements from some other water heater thing? if not than where on the net is the cheapest place to order them (i am in canada)
Re: Cheapest way to aquire heating elements?
Posted: Mon Mar 01, 2010 4:20 pm
by rad14701
I just walk into Home Depot or Lowe's and pay ~$10.00 USD for a 120V 1500W element... Even the most expensive 240V elements are only in the ~$30.00 USD range with most of them under ~$20.00 USD...
Posted: Mon Mar 01, 2010 4:34 pm
by toofless one
beat me to it RAD.
i dont use them, but ive seen them at home depot for those prices.
Posted: Mon Mar 01, 2010 6:52 pm
by squidd
Also, try to get the Ultra Low Density one if you can.
It looks like a doubled up wiggly snake.
squidd
Posted: Mon Mar 01, 2010 11:07 pm
by hacker
$10! Wow that's cheap you yanks got it alright geez
What about those of us who have a keg which isn't flat on the bottom (wait, are you intending on putting this element inside the still?) and need to use a burner, any ideas where to get one in Australia?
Posted: Tue Mar 02, 2010 12:16 am
by scarecrow
hacker wrote:$10! Wow that's cheap you yanks got it alright geez
One what? keg,element or burner?
Elements can be got from any electrical outlet at about $25.00 + and burners can be got from any BBQ place, Bunnings or camping supplies. Even BCF has them. 3 ring banjo for about $35.00.
Kegs I get from the tip for about $5.00 ea
scarecrow
Posted: Tue Mar 02, 2010 12:27 am
by olddog
Which State are you in Scarecrow?
OD
Posted: Tue Mar 02, 2010 1:53 am
by hacker
ok cool; how do i go about getting a gas bottle? same place as above? where do you get em filled? same as above lol?
Posted: Tue Mar 02, 2010 12:58 pm
by toofless one
you can get propane from a grocery store here in the states. i dont know why you would need propane with an electric element
dont take this personally, but it sounds like you need some more reading and research. we all do at some point.
these elements are not the hot plate types, they are elements for hot water heaters. they would be internal. but if you use propane, you wont be using electic heat. you got some basic things that need worked out. read on my friend....
Posted: Tue Mar 02, 2010 10:57 pm
by scarecrow
olddog wrote:Which State are you in Scarecrow?
Usually confusion or panic, sometimes disbelief.
I'm in far, far, far northern NSW. If I stand out the front and have a squirt, I'd be pissin' into Qld.
PS. hacker, your startin' to scare me.
scarecrow
