Condenser help
jackson98
Condenser help
Post by jackson98 »
i am building a column still, a 2" by 48" column with a 12" condenser. in the condenser ill have a 8" copper coil, is that enough to knock down the vapor? if not i was thinking about putting a jacket water around the outside of the condenser to help knock it down. I guess what i'm saying is can you knock down to much of the vapor?
Kentucky shinner
Re: Condenser help
Post by Kentucky shinner »
is it a double coil or single coil? if it is a single you my need to use some copper pot scrubbers in the coil to help.
Dnderhead
Re: Condenser help
Post by Dnderhead »
no you cant knock to much as you condense all that goes beyond the take off so none escapes the top.
