filtering?
larisk
filtering?
Post by larisk »
i've just distilled my turbo wash for the second time. do i still need to filter it? it smells better than a single distilation but its not odourless.
is it still called a spirit run if your usinf a reflux still?
Dnderhead
Re: filtering?
Post by Dnderhead »
ditch the turbos!
ya you git higher ABV wash but then you throw more away in cuts.
go to "tried and true recipes" some are quit simple and will be much better.
larisk
Re: filtering?
Post by larisk »
that was my last turbo. i've aleady discovered the magic of birdwatchers recipe.
i was just curious as to whether running it twice turbo or otherwise eliminated the need for carbon filtering
vicrider
Re: filtering?
Post by vicrider »
larisk wrote: i was just curious as to whether running it twice turbo or otherwise eliminated the need for carbon filtering
That depends on your tastes. If you like it, it's OK. IF not, and you have the carbon, filter it. Or you could just use it for parts cleaner and chalk one up to experience. :wink:
"The test of the machine is the satisfaction it gives you. There isn't any other test. If the machine produces tranquility it's right. If it disturbs you it's wrong until either the machine or your mind is changed."
