Continuous stripper power calculations
We don’t condone the use of Continuous Stripping stills as a method of running 24/7 as this is a commercial setup only .
Home distillers should never leave any still run unattended and Continuous strippers should not be operated for longer periods than a Batch stripping session would typically be run to minimise operator fatigue..
manu de hanoi
Post by manu de hanoi »
Hi all,
Here is an excel file I made (15 kb) for computing the power required for continuous stripping
http://www.stainlessstuff.net/up/contin ... ations.xls
here is the content :
Code: Select all
Power calculations for continuous stripper
	water	etoh
specif heat vapo 	2246000	841000	J/kg
heating 	4100	2460	J/k/kg
	 abv %	mass %
out	40	34,46920052	boiling temp for output	96	C
in 	10	8,060067423
ethanol density kg/l	0,789
wash input rate	25	l/hour
input wash temp	20	C
spent wash flow rate	18,75	l/hour	6150000	J/hour
output flow rate	6,25	l/hour
mass flow rate for output etoh	1,699762451	kg/hour	317787,5878	J/hour
mass flow rate for output water	4,095674967	kg/hour	1276212,32	J/hour
		total	1593999,908	J/hour
Evaporation:		etoh	1429500,221	J/hour
		water	9198885,976	J/hour
		total	10628386,2	J/hour
grand total	18372386,11	J/hour
power required	5103,440585	watts
1) Can someone double check the calculus ?
2) some very interesting points :
-if the output abv can be raised from 40 to 50 % abv the power required drops from 5103 Watts to 4300 W (or a bit less considering the boiling point lowers too)
-by using a wash preheater to heat the wash from 20 to 50 C, the power required drops from 5103 Watts to 4288 W
- with 50% abv and a wash preheater, the power required drops from 5103 Watts to 3490 W
it's so good i would not be surprised if I made a mistake
This topic has 23 more replies
Register Login
