Howdy guys, near have all the components to finish making my column still. The only thing i need now is the tri-clover clamp. I have found a supplier but just need to know what size i should buy. Aussie guys in the know, i have a CUB or (Gulp) Boags keg, 50l. Do i need to order a 2" or 2.5".
Cheers
Me
What size????
Re: What size????
Sorry should of said i am using a 2" column. I asked for the 2" so i hope that is the right size.
Re: What size????
If you ask for one to fit a 2"tube, you will get the right one.
OD
OD
Re: What size????
The place i rang did not know much about them, they had to ring another store in the country to see if they had them. So will take my chances with the 2", if it don't fit i can always return it i suppose......maybe.
Re: What size????
I'm at the bottom.......................in Tassie. I ordered it through Roberts.
Re: What size????
I could have told you the WA suppliers, but not familiar with Tassie. Glad you got fixed up though.
OD
OD
Re: What size????
Thanks for looking anyway, that should be the last part i am waiting for before i put it all together. Incase you were wondering i am having a crack at making this http://homedistiller.org/forum/viewtopi ... 17&t=11031 Funny enough i came across the same plans he has on the table. You got to love the internet.
Glen
Glen
Re: What size????
Those are plans for LM...that's my rig from a year ago, but VM has proved to be better. Look at VM and then decide.
LM remains my 'mode-de-favourite' cos that's what I got. 95%+With flavour acordin to severe cuts after a single run. That's a maximum of 1/3 hearts and it's worth it. Quantity is forward compatible. Go for quality and forward the quantity to the next run.
