Graham Condenser
O'Mahony
Graham Condenser
Post by O'Mahony »
I am hoping that this unit will answer for a product cooler. Material used: 1.5" /38mm pipe, 6" / 152mm long and the coil is formed with 1/4" / 6mm tubing. The coil utilized a bit over 4' / 1.25 m of tubing inside the condenser. The brass fittings (water) are 3/8" / 9.5mm.
A bit of a wild guess as to sizing, I hope to test the knock down power of this unit later today in the wife kitchen. I will post results. Cheers, O'Mahony
ScottishBoy
Re: Graham Condenser
Post by ScottishBoy »
I would say that will probably cool it off and then some...;)
ScottishBoy
HD Survival in a Nutshell...
Bayou-Ruler
Post by Bayou-Ruler »
It sure is perdy :P
Bayou Ethanol
Ethanol Fuel Producer
AFP-LA-15027
http://www.BayouEthanol.com" onclick="window.open(this.href);return false;" rel="nofollow
Very nice.
I could prolly throw the fires of hell at mine. But I was trying to find a use for my remaining 4"
rednose
Post by rednose »
I have built this some time ago just a little shorter with two end caps.
It works very well and yours will cool down even more.
Apollo with bok and "egg" graham condenser
MuleKicker
Post by MuleKicker »
Very nice... And shinny. So the function of a Blanikdog condenser, I mean graham condenser, is too cool the already condensed distillate? So that the hydrometer readings are more acurate or what? Ive been wonderin. Looks like fun to build. Alls i need is an excuse to build more accessories. :lol:
-Control Freak-
AKA MulekickerHDbrownNose
Think the Graham is more about a coiled worm in a liebig type jacket.
Size and what you are using it for is more or less acidemic.
MuleKicker
Gottcha. Little bastards are efficient then.
-Control Freak-
rednose
Post by rednose »
LWTCS wrote:Think the Graham is more about a coiled worm in a liebig type jacket.
Yup, unless most worms are open without lid, like the one in the pic, the Graham is a closed system, I use it in the Twins (closed Worm).
They are compact and close as effective as a Shotgun condenser, but more expensive to built than a Liebig.
Who's rig is that Joe?
olddog
Post by olddog »
I am happy with mine, it's a 3/8 coil inside a 3"casing, and its seems it will knock down everything so far. :mrgreen: :mrgreen:
OD
rednose
Post by rednose »
I dunno whom's rig it is Larry.
I saw it once while surfing and saved it, it's one of the most beautiful home stills I've seen.
Good for a desktop wallpaper if token the pic in nearly dark between some trees.
