I made the median vogue today the first run witch I tossed came out 150 proof. I tempered it to 80 proof just for research purposes it was pretty and clear.
On my second run witch I intended on keeping came out 165 proof. I tempered it to 80 proof and it turned cloudy on me I must have collected to much and got some tails in it. anyway I have found out making likker is "WORK" . Should I toss the cloudy batch? Its no big deal it was less than a quart. it"s a 2.5 gal wash pot still with a thumper.
My very first run
My very first run
The secret to creativity is knowing how to hide your sources.
Re: My very first run
if it is just cloudy you can rerun. just add it to your next boiler full.
the first run you should discard anyway as you git the "still cleanings"
if it was a pot still you either ran to fast or took to much.
Thanks it took about 6 hrs on the second run I tried to run it slow I didn't wont to bump it. I think where I went wrong I miss collocated the ABV of my wash. I'm trying to use temp to run my rig with but that's not as easy for me as I thought it would be.
A thermometer on a pot still is as useful as a bicycle is to a fish. Do yourself a favour and do some research in the reading lounge.
Cumudgeon and loving it.
