Hydrometer correction for tempature.
TN.Frank
Post by TN.Frank »
I have a proof/% Hydrometer that's calibrated for 60deg.F. If I want 80 proof what proof/% should I read at 75deg F.? Thanks.
In God We Trust, All Others Pay Cash.
Grayson_Stewart
Post by Grayson_Stewart »
searched google with the terms "Alcohol Temperature Correction Hydrometer" and got this http://members.tripod.com/~BRotter/Calc ... dSugAl.htm" onclick="window.open(this.href);return false;" rel="nofollow
Go figure.
TN.Frank
Post by TN.Frank »
Thanks, I generally hit google but today I'm just being lazy,LOL. For 25C it had a 1.0, does that mean to add 1 proof to what I get or what? They don't make it very clear do they.
knuklehead
Post by knuklehead »
If I am not mistaken that is a corrections chart for wash hydrometer, not a proof hydrometer. Temperature corrections for proof hydrometers is not really as simple as a basic chart where you add or subtract a certain amount for every degree you are out. If you have 40 proof at 70 F it will be out by a certain amount. If you have 180 proof at 70 F it will also be out but by a differant amount then the 40 proof was out. My corrections chart is 10 pages long, lol.
Dane Cook
knuklehead
TNF, my chart is in metic and my hydrometer is calibrated at 20C but I converted your figures and have come up with:
At 75F 80 proof will read 87 proof
Dane Cook
TN.Frank
Post by TN.Frank »
Thanks Knuklehead. I cut the stuff I rant off somewhere between 85-90 proof yesterday. That should give me a "true" 80 proof or there abouts. Have a good one pard and thanks for the great info. :D
Guest
Post by Guest »
TN Frank here is a link you can enter your temp and abv readings and it will spit out the corrected strenth.
http://www.distillery-yeast.com/distill ... ometer.htm" onclick="window.open(this.href);return false;" rel="nofollow
I can't vouch for accuracy just yet but the numbers I plugged in seemed reasonable. Hope this helps you.
Transplanted Hillbilly
PS if you can only measure deg.F heres the conversion
deg.C= 5/9 x (deg.F - 32)
TN.Frank
Post by TN.Frank »
Thanks for the link TH. :wink:
knuklehead
The calculator is simplifying it to:
For every degree C over the temperature your alcohol meter is calibrated at subtract 0.3% (0.6 proof) form the reading.
For every degree C below the temperature your alcohol meter is calibrated at add 0.3% (0.6 proof) form the reading
I think that translates to:
For every degree F over the temperature your alcohol meter is calibrated at subtract 0.5% (1 proof) form the reading.
for every degree F under the temperature your alcohol meter is calibrated at add 1.5% (1 proof) form the reading.
Dane Cook
