Hello everybody,
I just finished reading The Compleat Distiller and I'm ready to spend all my money chasing the dream. I know nothing about anything except for the chemistry of how distillation works. The plumbing mechanics will be a "learn as I go" ordeal.
So my first question is how to coil 1/4" copper tubing (I got from an ice maker installation kit) into a tight reflux coil without crimping. And I don't want to put the time into making a grooved mold (yet). I'm going to make just a single coil for now with an inside diameter of about 1 1/4". I'm assuming my column is going to be about 2", unless you guys think it's better to go with a bigger diameter column?
I read the trick of putting salt in the tube and it worked quite well when I tried it with a small peice, but I fear it might be too difficult to pack a 15' peice with salt. So I was thinking Is it possible to fill the tube with water and then seal the ends off in order to do the same job as packing it with salt?
How to coil copper tubing?
