Diluting my alcohol
crazyk78
Diluting my alcohol
Post by crazyk78 »
Guys can I ask a quick question about dilution.
I have 96% alcohol that I've distilled.
Now lets just say its 2 litres.
If I add 2 litres of water, then it will drop to 48%.
If I wanted to get 40% how much water would I need to add to the 96% ?
Is the answer 2.25l ?
What is the formula for dilution?
Thanks,
HookLine
Re: Diluting my alcohol
Post by HookLine »
There is a dilution calculator on the mother site.
Be safe.
Be discreet.
And have fun.
Filby
Post by Filby »
2000ml/0.40*0.96=4800
4800-2000=2800ml to get to 40%
Well that should be right :)
Mud Mechanik
Post by Mud Mechanik »
http://homedistiller.org/calcs/calc" onclick="window.open(this.href);return false;" rel="nofollow
Try this
Mud Mechanik
http://homedistiller.org/calcs/dilute" onclick="window.open(this.href);return false;" rel="nofollow
Sorry, the first one was the wrong calculator.
crazyk78
Post by crazyk78 »
Thanks guys. I did do a search in the forums but didn't even think of the parent site.
Cheers,
DOLIKEADRINK
Post by DOLIKEADRINK »
Howdy Fellow AUSSIE
It took me a while to find it as also, It makes it all to easy, Just the way us AUSSIE'S like it.
Cheers: Dolikeadrink
"Your putting on the agony but missing all the style" Ya want a good Still PM olddog
Ayay
Post by Ayay »
Use the alcometer. Eyeball the levels, add water and test. Hopefully you'll need a little more water and test again. I can get within 2% quicker than by calculating and the final result is what I write on the label. It doesn't have to be any particular number; 45% is the ballpark and I can mostly hit 45% on the third test and an error will read 42%, but I can live with that...just pour a little more in the glass. This is hobby?
No amount of calculating can be more accurate than reading the miniscus.
crazyk78
Post by crazyk78 »
Hey DOLIKEADRINK go us aussies.
Ayay..only issue I have with that method is that I need to make simple syrups for my limocello and need to put it all in there in one hit or it will distort my flavour. This is because I strip the lemons with the 96 %.
Cheers and thanks for the advice anyways always appreciated.
