Damn blue distillate - again
scarecrow
Post by scarecrow »
I've just stripped 20 litres of my neutral wash and it has a very slight blue tinge. :shock: Never happened before with my neutral wash (I've made about 20 batches). Same recipe.
I had the last strip run of my UJSSM do the same thing. Again, after more than 30 batches, it has never happened before.
My still and all lines get a rinse with clean water before every run, and this is always checked for undesirables. It's always clean. :D
pH of the distillate is 4.3. It's cloudy because I strip to 10%.
The only difference I can point to is it sat a bit longer than normal because I went on a 2 week trip to Van Diemen's Land.
It went dry in 10 days and it then sat for 4 weeks. It usually sits for 10 - 14 days and then I run it. The smell in the fermenter was slightly vinegary (pH 4.4) and slightly sour in taste.
It needs to have a spirit run done, but should I dump it (and the UJSSM) and start a fresh batch. The SM is up to it's 6th gen. I start again after 10.
I've checked other posts for this phenomena, but nothing really nails it down.
scarecrow
This topic has 72 more replies
Register Login
