Coupla designs I came up with. Opinions?
TK Spirits
Post by TK Spirits »
I was sitting around and I started to doodle some new pot still sketches/ideas. I figured these should go up here to see if anyone else liked them. Please tell me what you think, or things that I should change to improve my product when I start distilling again.
You can ignore the drawing with the leibig condenser and thumper feeding to the coil condenser, That was just a comparison between condenser designs meshed into one.
This one is just a section of the 18" tall column of the picture below it, to show the copper pot scrubber inside.
-TK-
Average Joe, I run my pot low and slow.
Mr.Spooky
Re: Coupla designs I came up with. Opinions?
Post by Mr.Spooky »
both of these ideas have been proven to work. some may say that they would use the thermometers, some would not.
spooky
Samohon
Post by Samohon »
As Mr Spooky said, all tried and tested... IMO, a pot still is about taste, smell and feel... I had a 3" dial thermometer on my pot still, but took it away and permanently sealed the thermocouple hole, I just found it useless with the temps all being different afforded to the wash I was stillin...
But all the above will give a nice likker... :D Like the drawings man... :wink:
♦♦ Samohon ♦♦
TK Spirits
Granted, all of these are rather straightforward and basic. I was reading a tidbit on the mother site and it was talking about different angles and different flavors, like <90* was for a lighter in flavored result, 90* was for an even/ medium flavored result, and >90* gave a heavier flavored result.
:D Has anyone had any success with those designs?
-TK-
Samohon
Post by Samohon »
TK Spirits wrote:Granted, all of these are rather straightforward and basic. I was reading a tidbit on the mother site and it was talking about different angles and different flavors, like <90* was for a lighter in flavored result, 90* was for an even/ medium flavored result, and >90* gave a heavier flavored result.
Now you've got it man, great resource the parent site.... :D
I like a light smooth flavour from my whiskey's so my route to the Liebig is 45° (◄90°)... I can tell ya, I'm getting a real nice whiskey from UJSSM / Sweet-feed / All Bran... I have some that has aged for 8 months, it has a dark amber, reddish colour, has undertones of being produced from an all grain, yet it's an UJSSM/Sweet-feed blend... Design is important in a pot still, just ask some commercial distillers who, when replacing a still, replicate everything right down to dent location and depth, never mind Length/Diameter of lynne arms and square meter-age of copper...
Keep us posted on yer way forward TK Spirits... :D
♦♦ Samohon ♦♦
TK Spirits
Samohon wrote:Now you've got it man, great resource the parent site.... :D
So you use a 45* bend and run a UJSSM/ Sweet-Feed/ All Bran? Do you use a thumper or is it just a one time through straight to yer lebig?
Are those recipes on the forum or are they your own?
-TK-
Samohon
Post by Samohon »
TK Spirits wrote:So you use a 45* bend and run a UJSSM/ Sweet-Feed/ All Bran? Do you use a thumper or is it just a one time through straight to yer lebig?
I always strip my ujssm/sweetfeed/all-bran, through the pot still as fast as I can... I dont use a thumper but when I do a spirit run after 3 or 4 stripping runs, I usually get 60%abv - 67%abv, perfect for ageing...
To see a diagram of my pot head, have a look Here...
The recipes are all from the Tried and True Recipes, Section...
Stop by and have a look...
♦♦ Samohon ♦♦
TK Spirits
So you use a combination of all three of these? or you have used all of these batches in a pot still and have had good results?
That is a really neat design. Would you mind if I replicated some of your elements into the still that I build?
-TK-
hoochinoo
Post by hoochinoo »
I could not read the length of copper from where it meets the boiler to the elbow where you have the thermometer... so i won't be able to comment on that.
If i were you, i would lose the thermometer, you don't need it... apply heat to the boiler and touch the plumbing and you can feel the heat travelling over the copper. After a while, you can feel the heat build up and then it shoots all the way to the condenser. That is what i see with my set up. It is my signla to be ready to see hooch coming out.
Also, i see that you have a 6 inch, copper length between where the first elbow is to the next one. I think that it is short. you are close to the boiler i think.
Then, finally, your condenser, 1/2 inch flex copper, perfect, can you specify how many feet you will be using to build the condenser?
TK Spirits
hoochinoo wrote:I could not read the length of copper from where it meets the boiler to the elbow where you have the thermometer... so i won't be able to comment on that.
The more I read the more I realize that I don't really need a thermometer, most are rather inaccurate when reading vapor temperature. I use my fingertips and touch the pipes and "feel" where the steam is. The 90º lyne arm is 18"x1".
So what would you recommend? 8"-10"?
I was using a 10'x 1/4"ID flex copper coil, but that was condensing TOO well, It would drop the temp to like 40º, so I'm thing anywhere from 5'-8'?
-TK-
LLave
Post by LLave »
Please forgive the new guy question, but what is the problem with condensing too well?
blanikdog
Post by blanikdog »
Yep, I have to admit that I'm also curious.
EDIT: AHHHHHHH 40c :!: :!: Must be using ice in the condenser water for some unknown reason.
Reason: Logic slipped into gear.
Cumudgeon and loving it.
TK Spirits
blanikdog wrote:Yep, I have to admit that I'm also curious.
I guess I was over cautious when I made my condenser, ans sometimes those runs can last long, I'd rather have the output too cold than too hot.
comes out 40ºF-60ºF (4ºC-15ºC)
I usually fill the center of the coil with ice and salt, then cold tap water.
My first condenser was a 1/4" ID x 10' in a solid block of ice, wanna talk about COLD :shock: I had to hold my hand near the top of the still to warm it back up. It still sits in my freezer, I use it only for fuels now..
-TK-
blanikdog
Post by blanikdog »
To each their own I guess. I use water and it works fine. Just out of curiosity, what size runs do you do??
TK Spirits
Somewhere in between moves, I have misplaced my old 20L, so I'm doing VERY small 1.5L stripping runs, which make work pretty tedious..
I'm getting pretty close to finding it, I have about 4 more boxes to dig through. I'm thinking of inviting some friends over, having a keg or two and just using that. What would you recommend Blanik?
-TK-
blanikdog
Post by blanikdog »
I can't see anything new about the design. A pot still is a pot still is a potstill. I fail to see how such a simple concept can be improved upon. All these things have been done before.
What would I recommend? I'd go for a simple potstill with a coil in a bucket - no ice, no salt, just water - and then I'd take the thermometer into your shed and pound it vigourously with a five pound hammer. But that's just me.
Stay Safe
blanikdog wrote:and then I'd take the thermometer into your shed and pound it vigourously with a five pound hammer.
I swear I imagined you said that to someone prior to reading this :lol:
BTW 12 pounder would likely offer less chance of repeatative motion injury....
TK Spirits
I figure go set up with a 20 lb. sledgehammer and just go to work :twisted:
-TK-
blanikdog
Post by blanikdog »
Well, I didn't wish to seem extreme. :twisted:
TK Spirits
Blanik, to date, how many thermometers have you gotten people to smash? :twisted:
-TK-
Just4funguy30
Post by Just4funguy30 »
Okay, sorry to all for the lateness of this, & I'm still(no pun intended) researching before I do my build. I was thinking though, in the first pic, the condenser is BEFORE the thumper?? Shouldn't it be AFTER the thumper? Please correct me if I'm wrong in this, & please explian why.
Thanks! :)
Can't comment on the OP's intent..But a condenser prior to the thumper wouldd act as a self filling aperatus for the thumper. This type of strategy can further boost ABV.
Just4funguy30
Okay, thanks.. I was thinking that it should be after the thumper for the heat that it would impart to the secondary. I wasn't sure if having it cool befre the thumper would give the thumper enough heat to cause a secondary distillation. This is why I'm still reading/learning before I build my own. Thank you soo much for your input! I knew I found this site for a reason!!! Thanks again, all here are awesome! I'm learning before I jump in, my thanks again to all of those that I have been reading & learning from.
One would apply cooling to fill the thumper to the assumed level then shut cooling off for the body of the run..
One would still need to employ a product condenser.
Just4funguy30
Okay, I get it. That's instead of charging the thumper prior to the run then, correct?
TK Spirits
The liebig before the thumper is nothing more than visual reference for aesthetics, I was still judging whether or not to have a single run or a thumper to condenser type rig. Sorry for the confusion. :D
EDIT** What LWTCS is saying is correct to answer your question.
-TK-
Just4funguy30
Okay, thanks!
