grain mills
grain mills
What do you grain mashers use to crack your grain. I've been using a combination of a blender and kitchen aid sausage grinder to do the job, but I'm not satisfied... sort of like using a screwdriver for a chisel thing....close, but not quite right. Anyone ever tried these brewers grain mills?
http://www.stpats.com/" onclick="window.open(this.href);return false;" rel="nofollow
look under the items for brewers, automatic mill.
for the record, no affiliation with the seller, I know I mention them a lot, but so far I'm a satisfied customer, aware of others horror stories tho...
It seems like this is a common design for brewers. Anyone used one?
I use an old coffee bean grinder (electric) I can usually grind 15 lbs of grain or so while my mash water is heating up. It helps to throw the grain in the oven for a few minutes, it makes it easier to grind. Corn I buy already rolled, but barley and malt I grind myself.
- Site Admin
Hobart
I bought an attachment for my wife's Hobart mixer which works pretty well, but my old hand-crank unit from http://www.morebeer.com still does most of my leg work. haven't tried their latest version which can be found here: http://www.morebeer.com/product.html?product_id=18599
I use the "Barley Crusher" and couldn't be more pleased! I have had it for a couple of years now and still have no complaints. I chose it over others for 3 reasons. 1) Nice sized hopper standard 2)adjustable roller gap also standard 3) an unbeatable price for all of the standard features. Rock solid crusher for a good price. Can you tell i'm a happy customer?
If any of you guys do some type of mash with a decent amount of barley in it, then it really is a worthy investment. I bought one cause the guy who was crushing my grain at the home brew shop did such a poor job of it. Once I got mine and figured out how tight to go with the gap without getting a stuck sparge I watched my effiency go WAY up. FYI effiency just means how much fermentables you are getting out of your grain.
I'm looking for a link for that name... You have one?
For those interested I found this:
http://www.aaoobfoods.com/graingrinders.htm#top" onclick="window.open(this.href);return false;" rel="nofollow
Dawg - I have never cracked corn with it so I really can't say how it would do. I have however used rye, wheat & 2-row barley - worked on all of them like a charm. The wheat I used last time seemed to bit a bit smaller so I just tightened up the gap a bit and away I went. I will say the harder the grain i.e. wheat (this also depends on how big you have the gap set) is a little tougher to crank than plain ol' 2 row. Not that it made a difference to my mill mind you, only my arm. I would imagine that it would work with corn just as well though cause it's really built sturdy. Worst case scenario you would have to run the corn through at a wider gap setting initally so it would be easier to crank and then just tighten up the gap and run it a second time to get it down to the crush size you want.
That or you could just hook up a drill motor to the mill and not have worry about how tough to crack the grain is.
