Forum for the discussion of any material/synthetics.Only posts with info /or links to research info allowed . Any posts recommend the use of any material without copy's or links to show proven research will be deleted
i have a huge aluminum funnel...i would like to use it at the top of my column to hold my spirits as they are being filtered...is there a problem using aluminum with dilluted spirits...thanks scott
Take the pipe that comes in a beer keg or other stainless pipe, drill a hole in a stainless bowl, tig weld pipe to bowl. Stainless funnels are expensive and hard to find.
Watershed wrote:I've got a bottle of 'Dansk' vodka which is aluminium - no trace of taint from it.
The aluminum bottle u have has a non-reactive resin on the inside of the can, just like beer, Aluminum reacts super badly with Alcohol at almost any proof, there are additives in the aluminum that leach out because the alcohol acts like a solvent, and these additives will hurt you. Just the same as galvinized steel, since a bit of lead is used in the galvinizing process.
If it dont burn it aint good!
Proudly tearing up the blacktop since 1996!
