I NEED HELP!!
Posted: Sat Mar 25, 2006 12:44 pm
I have read read and re-read the homedistiller section on distiling a wash. This is what I am doing
Using a Turbo Yeast from Still Spirits
20L of Natural Spring Water (from bottles)
I let the wash settle for ~2 weeks siphoned the clear stuff and let it settle again,
made a flour and water gasket
The Still
S.S. Beer Keg (cleaned several times)
Propane burner
40" Reflux Column Valved type
S.S. "Probe" digital type thermometer, held in place by a cork at the top of the column
Oh ya Column is made of copper (2")
3" condensor
Ice water running through a pump into the condensor to cool the vapor
2:08 placed wash in pot
2:34 first sign of vapor at the top of the condensor turned on cooling
temp fluctuated around 77/78 degrees C and then i balanced the heat input with the cooling and it has stayed at 77 for ~ 45mins
I let the column run under flux reflux for ~10mins
Opened the offtake valve at 2:45
watched the drip and calibrated it to be ~1 drip/10secs
Problem
The distillate is cloudy, what am I doing wrong
The only thing I can think of is that I may have dropped some "dough" from the gasket in the wash. could this cause the clouding????
I am in the process of runing this as I write
I need help ASAP.
The Still
Propane burner
3" condensor
Problem
I need help ASAP.
