Multi core liebig
Multi core liebig
Well folks I thought you might like to think about this. The usual route for more capacity is to increase the size of your liebig and to install a turbulator. You need to do that as the distance to a cold surface gets too big and efficiency drops off.
You really are better off with a long condenser with a smaller inner. But it SUCKS and is as inconvenient as well something really inconvenient
So go for that plan but chop the core into 3 or 5 sections and put them in a common outer jacket.
Reduces the length for convenience. Oh and just for the hell of it wrap it into a spiral too.
More to follow
More to follow
Re: Multi core liebig
Holy moly! Nice Myles. Real nice. What sizes are they? And how did you get the bigger stuff coiled? That would be cool for my pot still.
I believe you have to put the smaller tubes inside while they are straight and bend them all at the same time, nice job myles!
Well I supose you could do that but I didn't. I just wrapped the coils on the same core and combined them afterwards. I wish it was a simple as that but it wasn't. I learned on the job as it wereBushman wrote:I believe you have to put the smaller tubes inside while they are straight and bend them all at the same time, nice job myles!
Size wise the 3 inners are each 10mm (just over 3/8") and the outer is 1". I didn't coil the outer, I got it for free and just cleaned it. The spacers will be taken out later, they were left over from a previous job but aid in keeping it rigid during assembly.
Total length will be about 7 foot and it is going on my column. I know its overkill but it will look good, and if I ever upgrade the boiler it will cope with any power input that I am likely to use.
I have the construction method sussed now just need to get the ends on and try it out.
heck, just mount the thing AROUND your column...
first sci-fi still...
william...
william...
tell me how hard it is to do... tell me how expensive it will be... just don't tell me what i can not do...
lead, follow, or get out of the way... ankle biters will be kicked...
•*´¯)¸.•*´¯)¤ª"˜¨¯¯¨˜"william..."˜¨¯¯¨˜"ª¤(¯`*•.¸(¯`*•
Is there no end to what you blokes will do????? Can't wait to hear how the bugger works.
Cumudgeon and loving it.
Don't worry it IS going around the column but it is not my idea.hackware wrote:heck, just mount the thing AROUND your column...
william...
I was inspired by "The Twisted Bitch" from duds2u http://homedistiller.org/forum/viewtopi ... =16&t=7865
Someone may have done the multi core liebig before but I don't remember seeing it.
It will be under this still head
Overkill???
Thats just crazy talk comming from you Myles
need to use words like scaleable and so forth
"In anticipation of future upgrades" perhaps
Nice idea myles, sorta like a twisted shotgun thingy...
Gotta love the inspiration these guys give to HD...
Waiting to see how she performs...
♦♦ Samohon ♦♦
How does it connect to the column?
You could call it the Bucketless Worm Shotgun.
I really do like it. I think I will be making something similar for my pot still.
Here you go folks, next stage of the story.
The outer really is 1" but the rest is metric, so the inners are actually 10mm and the fittings are 22mm and 28mm. This is a brass manifold for underfloor heating. It is a female 22mm end cap with a thick drilled base, and they come with 2, 3 or 4 holes to take 6, 8 or 10mm tube.
Now it will just fit into 28mm tube so it passes through a 28mm fitting with ease. Solder in a length of 22mm tube, file out the endstops from a 22-28mm reducer, slide that onto the 22mm tube and push the lot into the 28mm fitting.
Do the same with the other end with a longer bit of 22mm tube and you get this.
Need to fit the reducers and hose connectors to the T's and leak test. I think that she has potential.
Edit: need to shorten the top 22mm tube abd fit some bends to connect up to the VM valve.
myles, what do you do in your "spare" time...
Looking good... Can't wait to here how it performs when completed...
I am building for stress relief at the moment. Re modelling the house and looking for a new job, as this one ends in a few months.
When all the copper work is done I will be re-doing the still room to accomodate the 3 main stills, and this might end up on the new glycol double boiler. I have too many condensers now, so can afford to play 'mix and match' to see what works best on which still.
Damn Myles
Do you do boiler work? Very nice, some good looking copper work
It is what you make it
The simple answer is yes. Unfortunately I am so snowed under with other life stuff at the moment I have not even finished my own new boiler yet. I tend to favour riveted and soldered seams and / or welsh seams. Sort of like this:bentstick wrote:Damn Myles
i vote myles for the HD rube goldberg award...
william...
william...
I really enjoy the pictures and tutorials, I am sure this thread is going to spur some other creative minds to look at different techniques!
extremely awesome. I am officially jealous
Knee deep in the cool and soothing waters of ol' Cripple Creek
WOW !
Great looking stuff Myles. I am still starring at the picture of your still head trying to figure out what I am looking at ?? Creative !!
I love the coiled Liebig and the concept of it winding around the column. I cant wait to see it assembled. Can I steal that idea?
Put some fancy valve handles on that rig! You know we love the fancy stuff.
Keep it up!!
MR
Keep it up!!
MR
The head is a VM with an offset heads column, and a heads trap on a horizontal coil. It has the option for batch dumping the heads and it could be run as an LM if you wanted, and possibly a few other modes if you really wanted.mash rookie wrote:WOW !
Keep it up!!
MR
In hindsight (on the column) there could be issues with pooling, partially due to the shallow slope angles but mainly because I didn't want to try and put a 90 degree bend in the inners. For this reason whilst this would be fine on a pot still, it might not actually work too well on the column.
A multi core straight liebig on the other hand would be just fine.
When I refurbish the still room there will be 3 main stills in there, so this will probably find a home on the glycol double boiler.
Willy Wonka ? Mad scientist? Who is this guy?
The copper whisperer.mash rookie wrote:Willy Wonka ? Mad scientist? Who is this guy?
For those who don't know,,,,,Myles is a multi-year defending champ.
Was that a missprint? champ or chimp!!!LWTCS wrote:For those who don't know,,,,,Myles is a multi-year defending champ.
Okay... The cats out of the bag, myles...
You guys must save these pics and quotes for the perfect moment, in my case instead of champ or chimp it would probably be chump!
I have decided. I am going to call you, "Willy Wonka, The Mad Scientist"
I cant wait to se her done with the coiled condensor wrapped around like a girl in a sexy dress. Pictures W.W.M.S!
My imagination is running wild.
I can see where we are going now. Crazy, fun, beautiful designs that make great stuff!!!! It a whole new world out there now Willy!
Form? function? form? function? Let the creativity begin.... oop's , I mean continue.
I just ran the numbers through both the condenser calculator and through the surface area calculator. They both work out within a gnats whisker of each other.
Relative to your standard liebig of 22mm in 28mm (that is 3/4" in 1" equivalent), by switching your inner to 3 10mm cores you should get a 35% increase in cooling capacity.
