Solderless still head?
I'm mulling over some ideas for building a still head (been researching the subject for a couple years now and am ready to put theory into practice).
The major trouble is that my soldering skills are nonexistent and I'm not sure I could learn them.
So, assuming that soldering is impossible, what are my options for pipe joins?
One thought I had was to use relatively thick copper tubing and use a tap&die to thread it to fit brass joints, and then teflon (ptfe) tape to ensure the seal. But copper is really soft and I'm not sure I could thread the pipes and leave enough thickness for strength...
Another possibility I found researching the forum is compression fittings. I'm not entirely clear how these work - can they be used anywhere?
The last possibility seems to be JB's waterweld. I'm not really excited about that idea, not because I'm worried about toxicity (it's not toxic) but because I'm sure I'd just make a clumsy mess with the stuff.
Has anyone made a reflux still head without soldering or welding?
For a boiler, I plan to use an electric water heater, 5-10 gallons, with the thermostat bypassed, which seems easy enough provided I stick it on a rheostat or timer or get the math right for the exact right wattage element.
Forget about the JB weld. I wouldn't use it in ANY part of the still. Hot alcohol vapors are alot more deteriorating than cool liquid alcohol. If the vapors come in contact with the JB weld, it will leach nasties into your product, and possible poison you.
If you don't want to solder just use compression fittings. (although it is very easy if you know how to hold a propane torch in your one hand and the solder in the other hand)
"Be nice to America, or we'll bring democracy to your country."
"The best things in life aren't things."
"Imagination is more important than Knowledge"-Albert Einstein
You should try soldering. I had never done it before, and I just did it on my new pot still. It wasn't really that hard. I bought a small torch and some small fittings to practice on. My solders aren't the prettiest, but they work, and they definitely got better as I did more. Good luck.
Here's some links with some info on soldering:
http://www.rd.com/content/openContent.d ... ntId=18276" onclick="window.open(this.href);return false;" rel="nofollow
http://www.umass.edu/classes/eng351/examples/pipe.htm" onclick="window.open(this.href);return false;" rel="nofollow
Cheers,
J
Cheers,
J
If you searched the forums what you should have found was about a hundred arguments just like this one with blind assertions for and against... proving nothing.I know this because I searched the forums. Then I read the MSDS.
the simple fact is... jb waterweld is non toxic and non reactive WITH WATER.
nobody has tested it with hot alcohol vapor and nobody is likely to.
You may be fond of the idea of inocence until proof of guilt but it isn't a model that works in the prevention of poisoning.
consider all materials suspect until you have proof that they are safe or the weight of hundreds of years of anecdotal experience showing their worth.
"a woman who drives you to drink is hard to find, most of them will make you drive yourself."
anon--
anon--
GDorn, If you are reluctant to solder, then use the compression fittings.
Using JBweld is a very very bad idea.
Hot alcohol is a very agressive solvent. I bet it will leach out goop from the JBweld into the hootch. Maybe even enough to cause the "weld" to fail. There is a difference between not disolvin enough JBWELD to make the weld fail, and disolving enough of the goop to contaminate the good hootch. Definately use somthing else to put your rig together.
Thank, Big J. I'd read up a bit on sweating, but didn't find anything quite as good as those two. I think maybe I'll give it a try.Big J wrote:You should try soldering. I had never done it before, and I just did it on my new pot still. It wasn't really that hard.
What would you suggest for attaching to a water heater outlet? I don't recall what they look like - maybe a compression fitting would be appropriate there?
they arent easy to explain.... best bet is to pick up a few and play with them... they will teach you of their ways.What about compression fittings? I don't get how they work, which was what I was asking.
anon--
anon--
Well,assuming soldering is impossible,youve comlicated things for yourself.I assure you,if you can brush your teeth,you can solder.There nothing to it! All you need to do is clean the joints your going to solder,apply flux,apply heat,and then apply the solder.First I usually wipe the joints down with white vinegar to remove any oils.Then I scour the joints to be soldered with some sandpaper or course steel wool.Then I apply the flux to both pieces to be soldered.Then put the joint together,and heat it evenly with a torch.When its hot enough touch the solder to the gap and it will melt and be sucked into it by capillary action.Very simple.Id be willing to solder a piece of pipe and take pictures if you think that would help you.Its really very simple.If youve never soldered you should try.I think maybe your thinking it requires skill like welding does.It doesnt.
i just got done pasting some of my still back together now its just drying. My stills never really got that much pressure yet I drilled a 1'' hole and plugged it with dryed flour paste so when it over pressures it pops out. It has over pressured before when the propane kicked in high for some reason and the jar almost went up in flames. Now i keep a wet cloth draped over the collection jar to keep vapors in.
