Micro still cooling
CopperMan
Micro still cooling
Post by CopperMan »
I just scrapped together a 2 gallon pot still for testing flavors out for rums and whiskeys out of some old fittings and a few feet of copper.
The arm is only 22'' long at a slight angle so theres not very much area for cooling. I will be using pretty low heat using a small propane burner on the lowest setting there is. I dont have a coil on it yet but if it wont cool without, one ill have to put one on. Would this be enough to actually cool the vapors down enough to condense?
http://i5.tinypic.com/14t3git.jpg" onclick="window.open(this.href);return false;" rel="nofollow
http://i6.tinypic.com/14t3kpl.jpg" onclick="window.open(this.href);return false;" rel="nofollow
I put the arm at 2 angles, i would think the one with the lower angle would be better to cool since it dosent have as much as a angle? Would this really make a difference? This probably wont work without a coil but im just checking to see what you guys think while my wash is still fermenting.
I know ill probably get flamed for having such a tiny still, but its only for testing flavors, and I have a 7.5 gallon keg still thats being converted to a reflux right now. :roll:
pothead
Post by pothead »
I like the second picture better.
There is NO WAY that that alone will cool the vapors. you will NEED a coil, or replace the longest piece of copper with a water jacket (liebig) condenser.
My first boiler wash 2 gallons. Then I downsized to a 6qt, then a 3 gallon, then 5 gallon, now 15 gallon. I am working on getting a 30 gallon stainless drum from someone I know.
"Be nice to America, or we'll bring democracy to your country."
"The best things in life aren't things."
"Imagination is more important than Knowledge"-Albert Einstein
CopperMan
Post by CopperMan »
If i do rig up a water jacket, how cold does this water actually need to be?
junkyard dawg
Post by junkyard dawg »
as long as its not hot it'll be fine. whats more important is that its flowing.
CopperMan
Post by CopperMan »
I was thinking just putting the longest tube through a bucket of cold water? Im really not smart enough to build a water jacket, but if it only has to be cold i think the bucket should work fine? I ran my old 7 gallon still with 4' of 1 1/8'' tubing and i didnt even coil it and it seemed to stay cool for a while? then after it got hot i just draped a cool rag over it?
CopperMan
Post by CopperMan »
anyone know if this would work?
Longhairedcountryboy
Post by Longhairedcountryboy »
That will work. Your going to need a bucket that is at least the size of your boiler or larger.
CopperMan
Post by CopperMan »
the boilers only 2 gallons, so ill be using a normal 5 gallon bucket. the still works perfectly on top of the grill and the bucket is sitting on the little shelf, then a copper tube runs to the ground to fill up the mason jars. Ill take some pics. thanks
