Low cost water pumps for cooling- In Australia
Anyone in Aust got a suggestion for a low cost (read sub $30) water pump for running my condensor??
Cheers,
Nimrod
Cheers,
Nimrod
pump
Dont know about Ausieland but I bought mine at a boating supply store. I'ts a bilge pump for use on larger boats. Sometimes after these pumps have been on a boat for several years the boat yards replace them because they are old and may fail at the wrong time. They will sometimes give these to you.
Pumps
http://www.aquariumproducts.com.au/category2_1.htm" onclick="window.open(this.href);return false;" rel="nofollow
Give that a try. I keep fish and played with a few of them,
Just keep the 'head hight' under control,
And that flow-rate is only about 40 times higher than any average distiller needs.linearone wrote:home depot has a beckett 385 gph 5/8" outlet with regulator pond pump for $39 us. I bought it last night.
People can and do cut corners by just having a single (bottom) reservoir and no heat exchanger, but then you need a whopping big reservoir, and may have to resort to using ice-blocks for cooling when the ambient temperature is high.
Anyone got any comments on the merits of submersible vs non-submersible pumps? It seems to me that the submersibles more often do what we want, ie, provide a modest flow-rate but a decent head-height.
I think you will find that most pumps are very simular in design, Most even take the same impeller..
The sub pump i have can be run internally or externally (but only for a short time)
the big orgasm running it internally is the water is taking the heat out of it.. They are quiet and a little leak isnt going too cause drama's!!
Ive got a 2400lph boy thats been pumping a tad over 6ft head for about 6 months, Never been turned off! and its still trooping. I'm going too retire it too a still coolant pump and get a 6000lph pump for the fishtank!.
