angle of leibig?
angle of leibig?
goin to build my leibig out of 1/2 and 1 copper and wondering if the angle matters at all. does a 45 or 20 degree angle make a diff. wanted to ask before i cut my pipe up.
Re: angle of leibig?
Shiner,
I found the following two links for ya by using the 'HD Google Search' at the top of the page...two different searches took ~30 seconds, these being the top hit of each...
Liebig Angle
Condenser Angle
May I humbly suggest you try that search function first in future so as not to upset the ol'timers ...they can get a bit cantankerous (jk)![Wink :ewink:](./images/smilies/icon_e_wink.gif)
Liebig Angle
Condenser Angle
Its just gotto slope downwards away from the column, the angle don't matter.
i tried searching but my computer is being retared. has it slow moments and i allways try that first. ![Very Happy :D](./images/smilies/icon_biggrin.gif)
10 to 15 dgrees below horozontal works well.
You can go uphill for a bit if you want some reflux.
If your making a pot still, try posting in the pot still forum. If your making a column, then I apologise in advance.
It is often a case of what is convenient. If you put in a 1 or even 2, 90 degree bends with a joint, it allows you to change the angle of the condenser. This is helpfull if you use different size containers. I like to strip straight into 1 gallon demijons, but use smaller containers on the spirit run.
On my leibig, I put a threaded union before the 90 degree elbow going down to the leibig, this way I can adjust it to any angle I want. But from my understanding it's up to your personal preference as far as the angle is concerned.
