Heating element voltage woes
Posted: Sun Jul 09, 2006 9:36 pm
I bought an ariston water heater to use as my boiler. It's 6 gallons, glass-lined, has a 3/4" threaded port on top that the column fits right into, and it's pretty light. Only one problem - it came with a 1500w element. I'm using only 1" copper tubing as the center column, so I knew that 1500w would be far too much. I figured, hey, no problem, I'll do what the forums and the books say to do - replace it with a 240v 3000w element and run it at 120v and end up with a 750w element.
Only the Ariston doesn't use a standard water heater element. I thought maybe the 'universal adapter kit' would be able to make it work, but no, the largest metal bracket just doesn't fit.
What are my options, here? Googling doesn't yield any alternative elements for that model, as far as I can tell.
I've read suggestions about dimmer switches (rheostats), but it seems like I'd need one rated for 13ish amps, and those aren't cheap.
I've read suggestions about autotransformers (variacs, powerstats) and that seems like closer to what I want. But again, they're rated for a certain amperage. Question: is the amperage rating on an autotransformer for the actual amperage after being knocked down 120v, or before? If it's after, I could get a 9amp autotransformer and run the whole thing at 80-85 volts, which yields between 650w and 750w...
Another idea I've had is to put another resistor in series with the heating element. I measured the ohms of the heating element (9.7 ohms) and did some math to determine that adding an extra 9.2 ohms in series would drop the amperage down to 6.25, yielding a 750w element. However, resistors are also rated, and finding one that'll handle 750w is not cheap - again, in the $100 range.
Yet another idea - a fixed transformer. You'd think a fixed transformer would be cheaper than a variable transformer... Doesn't seem to be the case. On digikey.com (great electronics supplier), a transformer to output 60v rated high enough to handle 6something amps (the closest such transformer) is $90.
Any other ideas? I'd thought about putting it on a 15-minute on/off timer, but it seems like the boilup/cooloff would be too pronounce and I'd probably have overflow and/or no reflux for periods of time.
