Shopping for a propane burner
Posted: Mon Apr 23, 2012 11:46 am
by oakback
I finished
my boka still and did a test run with vinegar and water, than with just water. It seemed to work great, but the turkey fryer I'm using isn't quite up to the task. It was too tall, and not wide enough to hold the keg. I used a few lengths of rebar to hold the keg on it (forming a triangle), but I don't like it.
I'm not sure what amount of BTUs are needed, but I was looking at
this one at Lowes. It's shorter and wide enough for a keg, and the reviews sound like it would heat sufficiently, and I like the price. Is this a good choice?
Re: Shopping for a propane burner
Posted: Mon Apr 23, 2012 1:09 pm
by moonshine guy
Look around for a Bayou KAB4. I have one and she works as fast as my electric 7500 watt heaters! I have seen them on eBay for as cheap as $55.00 plus shipping. I want to say that it is 230k btu, but don't hold me to that. She is HOT!
Posted: Mon Apr 23, 2012 4:40 pm
by chopper35nj
Oakback, I would suggest you search the index for "car rim burner" I am definatly doing that.
Posted: Mon Apr 23, 2012 4:59 pm
by wendellbaker
I got one at Northern Tool shipped with a connector for $75 or so. Works fine. A bit slow on the initial warm up but perfect for the run. If you go that route, it's a good one to start with. $55 for 230K btu is a lot more that the 35k they offer but it works.
On a related matter. I'm considering upgrading to electric. Propane makes me nervous for a few reasons. Open flames and carbon monoxide are just two quick ones. It seems to me, and I'm sure there are people who use propane and swear by it, most experienced people around here prefer the control of electric. There's quite a few good threads about the benefits of both.
Either way, congrats on completing the new build and enjoy it.
WB
Posted: Mon Apr 23, 2012 5:52 pm
by Bayou-Ruler
Works Great!
![Image](http://www.rebelbrewer.com/shoppingcart/product_images/r/floor_standing_burner__63331_zoom.jpg)
Posted: Mon Apr 23, 2012 8:02 pm
by WhiskeyRiver
I've ordered a couple of things from these guys and they seem to have quality stuff. This burner is 185K BTU and a 22" wide cooking surface. Not sure how they compare on price to others.
http://bayouclassicdepot.com/sp40-bayou ... burner.htm" onclick="window.open(this.href);return false;" rel="nofollow
Posted: Tue Apr 24, 2012 4:12 am
by NcHooch
X2 on the banjo burner, burns cleaner , less soot when I run it on low.
Posted: Tue Apr 24, 2012 6:55 am
by oakback
Thanks for all the replies!
WB
I'm comfortable with propane, but the main benefit for its use is mobility. Where I'm using my still, I don't have access to electricity without using 150' of extension cord, which I don't like doing if I can help it.
chopper35nj wrote:Oakback, I would suggest you search the index for "car rim burner" I am definatly doing that.
I like that idea, but I don't have access to a big enough rim, and I don't know how to weld. If I bought a rim, bought the burner parts, and paid someone to weld it together, I'd spend as much as I would buying an already-made burner.
Posted: Tue Apr 24, 2012 7:20 am
by DFitz
http://stores.southlandoutdoorsandmore. ... as+Cookers" onclick="window.open(this.href);return false;" rel="nofollow
This is the best price I've found on the net. Couldn't find it locally.
Posted: Tue Apr 24, 2012 9:42 pm
by chopper35nj
If you have more time than money like me, you could build that without welding. I will weld mine just because I have the welder but it could be built with a hack saw, drill and a few hand tools. A few nuts and bolts and you're golden. You already have the burner on your turkey fryer, I will likely sacrifice mine to build one and an old rim is $5.00 at any junk yard. I agree that those burners put off a lot of soot down low and they are likely not as efficient as the the other examples but you've already got it. I do have to admit that if I could afford to I would buy one of the banjo burners myself.
Good luck
Cheers
Chopper
Posted: Wed Apr 25, 2012 4:47 am
by oakback
The turkey fryer was a loaner from my friend, so I can't take it apart.
After seeing all the recommendations for Bayou Classic burners, I went ahead and bought the Bayou Classic burner that Lowes sells. I tested it out, it's like an jet's afterburner, fun stuff.
Posted: Wed May 02, 2012 4:00 pm
by vdoubleu
Bayou-Ruler wrote:Works Great!
just bought one. this thing is a work of art, hope it works as good as it looks.
Posted: Thu May 03, 2012 4:41 am
by Bayou-Ruler
vdoubleu wrote:Bayou-Ruler wrote:Works Great!
It does, I know I'm very happy with mine
