Does it have to be a NEEDLE valve?
I've decided on the Bokabob design and am now sourcing the parts. Saw this 1/4" ball valve on ebay, is it suitable?
http://cgi.ebay.co.uk/ws/eBayISAPI.dll? ... %3AIT&rd=1" onclick="window.open(this.href);return false;" rel="nofollow
The idea of the needle valve is to allow precision control over the offtake rate (as in like 1 drop per second, to take it down to 1 drop 10 secs).
The ball valve wont give you anywhere as much control. You can try it, but i reacon you will be kicking yourself later, as you wont have much control.
Well, thats just what makes sense to me.
37.5" fractioning still.
50L SS Sankey keg
20L SS stockpot
Im kinda new here, be nice![Smile :)](./images/smilies/icon_smile.gif)
50L SS Sankey keg
20L SS stockpot
Thanks for the replies. Not quite sure why 1 per second is wanted when 10+ drops are available, something to do with the other 'drops' going back for more refluxing?
I'll be using a mains output regulator on a hotplate, can get a lightbulb to glow less than a candle with it so no probs (I hope) getting 1 drop per 10 secs if that's what I want.
Power control works for RR controll only with constant cooling CM system. Unless you know exactly what you are doing with power regulators I suggest you study the subject further. It's quite likely that you'll either fry the regulator or create disturbances to electric mains network bringing some more or less official people to your door. Those lightbulbs are usually 40-100W while your heating element is likely from 1000 to 2000 wats.Arthur wrote:Thanks for the replies. Not quite sure why 1 per second is wanted when 10+ drops are available, something to do with the other 'drops' going back for more refluxing?
- Riku
What's RR control?
The regulator is from Maplin, it's not a light dimmer. The blurb says it'll handle 2.6 Kw with a suitable heatsink (which I gave it). It's supposed to turn on/off at zero voltage on the mains but yep it is a bit dirty, it stuffs up my self built usb soundcard when running the little pot still. Haven't put my scope on the mains yet, will do that before using it wiith a bigger load than 480w.
If it's real bad I'll look for a true zero voltage crossover regulator, now I'm used to using a regulator, too cool to do without, love the control it gives me.![Smile :)](./images/smilies/icon_smile.gif)
Ahhh... so the higher the reflux ratio the purer the product...
After thinking about the regulator, I've decided I don't want the potential problems and altering the water flow through the condensor gives enough control for most here so good enough for me.
I have now sourced a 1/4" needle valve but the seller doesn't know what it's made of. (So he says.) Cheap enough for me to take a chance and if it sticks to a magnet I'll bin it.
You are overcomplicating things - this is not rocket science. You can buy a suitable brass needle valve at almost any hardware store for about $3.
I like the tube compression fitting style that use the little swage rings, since they make it very fast and easy to try modifications like adding a Leibig or changing the output tube. I use the same one on my 1-1/2" and 2" columns, since switching it back and forth only takes a minute.
fahdoul, most of us here in the UK us tinkerers can only dream of hardware stores like you have.
The valve arrived and it's stainless, so far so good. For controlling the water flow I was going to use the ball valve on the washing machine hose but thanks to hornedrhodent I'll get another needle valve for that.
According to the RS Catalogue they are. In fact the catalogue picture makes them seem shiny whereas the eBay pic shows them dull, pretty much as you would expect for nickle.
Either way, I expect the quickest and most thorough way to clean them up, if it is necessary at all, would be to plate the nickle off the valves onto something else.
HOMEMADE - A Peaceful Revolution
That's exactly what I've got.
Edit:
I took a dremel to it and applied the sanding drum. I dug in over 1/16" and it's bright shiny metal.
Have now noticed a glint of brass colour. Don't know how I missed it at first.
So.... Is nickle safe? Will the ethanol destroy it and if so, is the brass underneath likely to have been coated with lead?
Edit:
