OK. I have seen this a few times now. I don't know what it is.
I cut my 95% ethanol with water (clean purified store bought water)
and ran it through my Z-filter, and the frst bottle that came out had what looked like ALchohal and water seperation (looked like Clear oil) when i shook it up, it went away and i haven't seen it since.
NOw i did a strippin run today, and i notcied that same thing again when i was pouring it into a carboy...
I have all copper no foriegn materials, straight sugar/turbo wash. and a spotless still.
My question is, When alchohal and water first get tossed together do they appear to not mix up at first?
I can't make the 1st bottle that i had it in show it.. and i have tried over and over.
What do you guys/gals think?
What is this Clear Oil?
Haven't noticed that kind of effect.....although when mixing high proof alcohol with water it seems to react and gives off a cloud of very fine bubbles. Though it might be outgassing of the solution due to the dissipated heat from bonds that are being formed between alcohol and water molecules.
Kui ei ole surmatõbi, siis saab viinast ikka abi...
