Too much packing?
hendecp
Location: Planet Earth, western hemisphere, in the "lower 48"
Too much packing?
Post by hendecp »
Let me start by saying that my still works fine and on my first alcohol run I was pulling 93% in the foreshots into the heads. I was running it in reflux mode at about 3-4 drops per second in my 2" Boka.
My question is about the packing and if I have too much, or can I reduce what I have in the column to use somewhere else? The column is 36" to the point where the coil head is connected. I bought a box of pure copper pot scrubbers off of amazon. There were about 40 scrubbers in the box. Now, they all fit inside the column packed in. Do I need this much in the column? It seems to work fine and it has lots of breathing room. I plan on using this as a pot still for the next few runs with UJSSM so I will remove the packing. But when I go back to neutral or total reflux still operation, do I need ALL of those scrubbies?
Thanks in advance!
Wherever you go, there you are..... But, where am I and how did I get here???
This topic has 3 more replies
Register Login
