Will these suffice on my flute???
Nimrod
Post by Nimrod »
Went back over Flute talk, Tried to HD Google search for olddog's sight glass tutorial mentioned around here several times. So, will these work for sight glasses????
http://www.pexsupply.com/Cello-WDSJ-32- ... -C-x-Compr" onclick="window.open(this.href);return false;" rel="nofollow
Or, would I be better off with these....http://www.pexsupply.com/Cello-WDFSJ-24 ... TG-x-Compr" onclick="window.open(this.href);return false;" rel="nofollow
QUICK! Don't CLICK HERE!
Please Click HERE to visit New distiller reading Lounge
RGB
guittarmaster
Re: Will these suffice on my flute???
Post by guittarmaster »
yes. Infact i have saved that same link that i pulled off of another thread. You have to pickle them to remove left over lead though....
2nd question, depends on the diameter of your column and how easly you want to watch it work.
GM
(edit: upon closer inspection they are copper. You should be fine, they look like brass fittings in the images...)
War is Peace
Freedom is Slavery
Ignorance is Strength
Nimrod
Post by Nimrod »
Well, I'm still undecided on 4" or 3".... Those 2 inchers would look bitchin on a 3" column. I think :esad:
RGB
NcHooch
Post by NcHooch »
Nimrod wrote:Went back over Flute talk, Tried to HD Google search for olddog's sight glass tutorial mentioned around here several times. So, will these work for sight glasses????
I used the Grainger 5UGA9 Trap Adapter, Copper to Slip, 1-1/2 In. ...good size for a 3"
NChooch
Nimrod
Post by Nimrod »
I do believe I remember seeing something of grainger on your build. I hope you don't mind that I will be closely replicating your toot flute, decided against bugle. Great news is, got the keg and there is a Grainger not far from here :thumbup:
RGB
NcHooch
Post by NcHooch »
Nimrod,
I included the bill of materials in the thread for a reason ... replicate away man.
Id recommend you use 80-90 of the .062 holes in the plates.
NChooch
Nimrod
Post by Nimrod »
NcHooch wrote:Nimrod,
Ahh, Thanks for that tip.... I will add it to the materials list in the notes section, Thanks :thumbup:
RGB
mash rookie
Post by mash rookie »
1-1/2” is plenty big enough to see into any size column. I have used Grainger trap adapters and love the brass nut look. The Pex supply one appears to be the same. Copper slip with brass nut. If it is copper, that is half price of Grainger. They seem to have really good prices. I have been to their web site several times but I have not ordered from them yet.
MR
guittarmaster
How did this work for sightglasses? Do you have an update to report?
War is Peace
Freedom is Slavery
emptyglass
Location: Victoria, Australia.Usually the shed. Sometimes the cellar.
Post by emptyglass »
I've seen a few with 3" glasses on 4" columns.
It looks like they are the gooly eyed kid with glasses on in 5th grade :egeek:
Maybe thier owners need glasses to see without squinting.
1.5" to 2" wil give you all the info you need.
Rastus
Post by Rastus »
Just a note on those 2" slip joints (on my list also)...
i actually called Cello and asked them about the item, and they confirmed it is Wrot copper, no lead, not brass.
I was quite concerned as the picture looks like brass to me.
quick edit to add: does anyone know what size the glass would need to be to fit the 2" slip joint?
I saw someone used them in a build but cannot remember who and which build it was :crazy:
have a great day!
Rastus
She was just a moonshiner,
But he loved her Still
wv_cooker
Post by wv_cooker »
Yep, they are copper and though not on a flute I used one on my LM rig to be able to see the reflux return. Worked perfectly for the last 6 month's or so. Actually McMaster & Carr sells borosilicate glass lens that fit perfectly. I used ptfe tape to wrap mine and it sealed perfectly, but it would be very easy to cut a gasket to fit out of ptfe sheet or cork sheet also available at McMaster & Carr.
edit: oops didn't see your question Rastus. The the hole in the nut is the advertised size. It would either be 2 1/4 I think. I think pex advertises the size on there site, but a call to them can answer your question. Mine was a 1 1/2" one and the glass is 1 3/4".
Rastus
Post by Rastus »
great... i had the bookmark for mcmaster & carr page good to see i was thinking where you went.... but the size is +1/4" maybe i will wait and measure with my calipers before i sink into the glass...
thanks for the info WV
catch you later
Rastus
Post by Rastus »
WV,
do you recall what thickness you got on that glass?
I was thinking 3/16" might be solid enough to ensure a good seal without breaking them i am ordering a few extra just in case i need a few in the future.
thanks for any help you can share
Rastus
wv_cooker
Post by wv_cooker »
Lol, this was one of my duh moments when I ordered my first glass. I first ordered a 1 1/2" x 1/8" when it arrived it slid right down the center of the bore without issue. While looking at the thickness I decided to go a little thicker and I did use the 3/16" thick one. So far 6 month's without an issue.
Rastus
Post by Rastus »
great thanks for the quick reply on that 3/16 is what i was thinking... my pex supply order should be in today !!! over $300 but hey all the hours i will be shaving off my times in the end !!!
have a great day
Rastus
Rastus
Post by Rastus »
as a follow up i did order the 2" trap adapter and then also ordered the Heat-Resistant Borosilicate Glass located here:
http://www.mcmaster.com/#glass-stock/=o6diyu" onclick="window.open(this.href);return false;" rel="nofollow
i got 2 1/4" dia. and 3/16" thick... perfect fit! :clap:
although the 2" trap adapter slooks like brass on the website, the body part is copper, and the nut part is brass.
it looks exactly like the 1 1/2" adapter only it is 2". i cut some nipples @ 1 1/4" long that i can clamp into a jig and cut with a hole saw for the radius of the 4" pipe, thus, make any mistakes on 2" copper pipe, not the expensive fitting. when i get them right , i can solder them into the adapter.
guittarmaster
Rastus wrote:as a follow up i did order the 2" trap adapter and then also ordered the Heat-Resistant Borosilicate Glass located here:
I'd love to pics of this.... If I'm not askign too much.
War is Peace
Freedom is Slavery
Rastus
Post by Rastus »
i realized i would need to start taking pictures sooner or later... thanks for giving me a reason... i will try and get some done this weekend...
i have to finalize the length of my main column and make the cut. that 4" L wont fit my pipe cutter :|
and i dont have a chop saw , but i realized if i am careful the table saw with a thin kerf carbide does good, although have to make multi pass it made damned clean work of my 2 & 3" copper last night as i was preparing the various components... once i get these ready. i will get them to posing for a build portrait. :ebiggrin:
Rastus
Post by Rastus »
here is a few pics of the sight glass 2" trap adapters along with the 2" tube i am adding on, they haven't been cut yet, and also what the glass looks like
the parts
the parts
the glass, nice looking lenses
glass with teflon tape wrapped on the edges
assembled
assembled
2" trap adapter with sight glass attached, and the extended 2" nipple that i will cut to shape of 4" pipe.
guittarmaster
:thumbup: :D That looks Great! I'm SOOO doing this for my sightglasses!
War is Peace
Freedom is Slavery
ProChargedHarley03
Post by ProChargedHarley03 »
I have the same fitting:-) this tread might help http://homedistiller.org/forum/viewtopi ... 32&t=26435
:clap:
wv_cooker
Post by wv_cooker »
They look really good Rastus.
