thinking out of the box about potatoes
Posted: Fri Oct 12, 2012 8:30 pm
by wfw52
ok shoot me down since I am a newbe at this , but why couldnt you take potatoes and run them raw through a semi comercial apple shredder and press the potatoe juice out of the pulp and heat it up say 150 F to break down the emzines. cool it add sugar to get what ever SG you want then pitch it ? save all the mess of makeing mash potatoes and straning it out before running it ?
any though on this hair brain Idea ?..........wfw
Re: thinking out of the box about potatoes
Posted: Fri Oct 12, 2012 8:59 pm
by Dnderhead
you will have starch water..you need enzymes to brake the starch into sugar..
Posted: Sat Oct 13, 2012 4:04 am
by rad14701
There also isn't enough water content in potatoes to press them like apples or grapes...
Posted: Sat Oct 13, 2012 8:42 am
by wfw52
Ok , you both shot me down ............. lame idea
Posted: Sun Oct 14, 2012 5:16 am
by Buccaneer Bob
wfw52 wrote:Ok , you both shot me down ............. lame idea
No, I don't think they really shot you down, just pointed out flaws in the process as you described it. And it's not a lame idea at all.
Check out HD's section entitled "
Using Potatoes".
Posted: Sun Oct 14, 2012 6:45 am
by astronomical
why go thru the hassle of conversion if you're fortifying with sugar?
Posted: Sun Oct 14, 2012 7:01 am
by rad14701
astronomical wrote:why go thru the hassle of conversion if you're fortifying with sugar?
I think we covered that with the whole pressing the potato juice out of the potatoes thing... The OP needs to research how to use potatoes properly, which has been covered in other topics and not worthy of repeating here...
Posted: Sun Oct 14, 2012 9:08 am
by Dnderhead
"Ok , you both shot me down ............. lame idea "
its not really lame ,but needs to be done right.adding things like potatoes/wheat/ others ,can alter the outcome of product.
Posted: Sun Oct 14, 2012 10:24 am
by lokibrew
Wfw52
You posted in the right forum - novice distillers
I would suggest some directed searches here on HD check out the HD Google search button in the header
I'd search the following:
Diastatic malt. - this will give plenty of results to the relative amounts of enzymes readily available in malted grains
Potato. You will find there are several experiments of fOlks already using potatoes and how they prepared them
Enzymes - there are several commercial enzymes you can add to a potato slurry with or without heating
The Russians were making vodka hundreds of years before potatoes were brought to Europe. I suspect they mashed with malted grain for conversion. From what I understand, potatoes were used because they're were cheap and plentiful AND you can ferment rotten potatoes. You just have to distill it a bunch of times so it doesn't taste like rotten potatoes
Report back on what you find!!! And good luck
Posted: Sun Oct 14, 2012 11:29 am
by wfw52
hey thanks for the tips lokibrew , I will definatly do more reading before I tackel the spud-mentation
Posted: Sun Oct 14, 2012 11:30 am
by Hawk_
What about making mashed potatoes and adding water and enzymes? The liquid would be much easier to extract after this point. Hell ill try it. I've got enough neutral for a year and I will have 2 fermenters available this week. One will now be for potato and the other for ujsmm.
Posted: Sun Oct 14, 2012 7:02 pm
by wfw52
let me know how that turns out hawkingrage............there's gotta be an easyier way to get them spuds into a bottle !!!
