Hello Distillers,
Tomorrow i am going to fire up my new still, i have roughtly 3 Gallons of stripped spirits, i measured the alcohol with my alcometer, it read at just over 63 %.
Out of interest , how much Good spirits should i get? after the cuts.
Thanks.
How much drinkables
I assume you're after pure 95.6 alcohol and not whisky, whiskey, rum or any other sort of flavored end result.
Now it's all dependent on your column. a tall (1-1.5m) and with an appropriate filling could get you cuts from everything from 20-60-20 to 20-80-0 or better. The taller your column the better result. If you want no tails you need an ARC. You can reduce the heads by using baking soda in the stripped wash.
- Husker
What is an ARC?vinifera:
