Valved internal reflux cooling problem
SideJob
Post by SideJob »
In theory a friend has an internal valved reflux still exactly as planned from homedistillation.com. It works great other than it does not have enough cooling ability. It has about 10' of 1/4" copper tubbing. Is there an easy way to bend 10' of 3/8 and put some 1/4" in the void in the center? In the spaces copper mouse guard could be placed. Has anyone has a similar problem? Any suggestions would be appriciated.
SIXFOOTER
Re: Valved internal reflux cooling problem
Post by SIXFOOTER »
I ran into the same thing when I built mine. I ended up making 2 coils, one inside the other and connected them together paralell with a piece of 3/8" in the midle as a Manifold and cold finger. It knocks down everything no problem
ipee7ABV
Post by ipee7ABV »
if i understand correctly you can add copper scrubbers betwen the coils for more knock down power
SideJob
Post by SideJob »
Ended up makig a coil of 1/4 ID 15' then inside that 17' of 1/4 OD. Will fill the center with copper mouse guard. Have not done a test run.
Vapour trails
Post by Vapour trails »
cold finger down the middle of the coil works well
