Another continuous stripping still
We don’t condone the use of Continuous Stripping stills as a method of running 24/7 as this is a commercial setup only .
Home distillers should never leave any still run unattended and Continuous strippers should not be operated for longer periods than a Batch stripping session would typically be run to minimise operator fatigue..
Maritimer
Post by Maritimer »
With 80 liters of Birdwatcher's wash to strip, I began to think of a continuous stripping still. This is a popular topic, but I wasn't able to find one like this.
Originally, I thought of a series of four teakettles, each one feeding its overflow into the next:
As the wash is fed into the first, some of the ethanol boils off and as more comes in, the overflow goes to the next kettle. The overflow will be depleted compared to the wash coming in. Then it boils off some ethanol, gets depleted some more, and its overflow goes to the next kettle. The waste coming out will have little ethanol left in it.
Then, to make it simpler, I put the four kettles into a stock pot and took off the vapour from one outlet.
Then I got rid of the kettles and came up with this:
The wash comes in via the lower gold pipe and exits via the upper green pipe. The cylindrical red things in each quadrant are 1000 watt teakettle heating elements. I can use my digitally-controlled-power power supply to tweak the power dissipated in each element.
The only difficulty in building this would be attaching the quadrant.
Would it be OK to use food grade silicone? It could easily withstand the temperature.
This topic has 28 more replies
Register Login
