Will this element be too big
If it plugs in, post it here.
bourbonbob
Post by bourbonbob »
I have almost completed this still, most of the material I got free (cost me $53 all up, $19 for the SS sink drain and $28 for 4' x 2" column, $6 for a reducer for the thermometer)......I put a 2400 watt 240 volt kettle element in it for getting to temp and I will add a smaller one (1200 - 1400) for the distilling. The boiler is 20 litre, column 2 inch.
I would like to try it just with the 2400 watt element :idea:
Will this element be a problem to distill with :?:
CoopsOz
Post by CoopsOz »
I think it will be to big, I tried running a 2.4 on my 1100mm column bokakob, it just ran too hot. I had to install a 1380 watt element.
bourbonbob
I thought that might be the case. I might be able to get a small kettle element.
No hurry, I have the pot still to get by with. :lol:
markx
Post by markx »
2.4kW will most likely be overkill for this setup. If you had a valved reflux design with a mighty loosely packed column, then you might squeeze this amount of power through the pipes but I advise to go for the 1.3kW element for now.
Kui ei ole surmatõbi, siis saab viinast ikka abi...
bourbonbob
I got a nice shiny 50 litre keg today, I will use it outdoors on a gas burner.
