Hey guys
Posted: Tue Dec 04, 2012 5:44 am
Sorry I would post pictures of my setup but I'm scared to be honest with the laws the way they are. Basically I use a boka with a full 6 foot reflux column. It's modular by design and I actually had a lot of fun building it. Getting the copper coupler silver soldered to the keg top was probably the most challengin part of the build. It ended up just having the right flux did the trick. Used some 308L to create a lip too. I took a lot of tips from your build section when building it including the cardboard ring wrapped in ptfe (who would have known). Good cork sheets without rubber are so expensive.
I made a pretty cool centering ring too and found a used box of copper scrubbers (just returns- they were all new without a box) for 23 bucks which turned out more than enough to fill the column. The condenser is a cold finger design around 10" long that turned out practically perfect thanks to the salt trick. Actually friend of mine asked how much it cost me- thought it was mass produced But having put all the love into the design and building and insulating for the cheapest I could. I still found it cost me a little over 400 dollars in the end. I bought two identical ss kegs both off craigslist- one for 10 bucks from a college student (unbelievable I know) and cut the tops out- one bigger than the other. The bigger ended top is used for the boiler top and sits on the smaller holed keg with the ptfe ring for a seal and drilled out 2 holes for ss bolts and wingnuts to lock it down. The other made a good 40L ss fermenter which cut out a top for using a old cutting board.
Some day I would like to make the top clear and sit the sg meter in there for monitoring. I use a cheap 10 dollar walmart aquarium heater and wrap the keg in the insulation used on the boka for the ferment. I also sit the keg on bricks which seems to help.
For all purposes it's a really nice modular still.. Run half or full column or pot with no column. The thing is the neighbor thinks I'm distilling water and I want to keep it that way. I love how people have no idea what they're looking at. I just make enough for friends and family and am so paranoid I stash the good stuff where noone would find it. And even if they did find it I have a cover story all made up about it being seagrams vodka. I always run safe with flour paste on hand and never had to use it. Have a fire extinguisher. Are any of you this paranoid? I have this dream that I'm getting fleece johnsoned in prison. Hell I'm jumping through a proxy for this site!
The laws are so messed up. I can actually order everclear here but I can't distill it? I have gasoline cans full of gas and gas/oil but I can't have a bottle of ethanol? Oh wait I can but it has to be made by a distillery. I built this still after pricing a 750ml bottle of 190 which costs $30 shipped. I will not be robbed to make some apple pie for christmas.
You guys are great and learned a lot. Just wanted to say thanks.
