All grain wash question
GUNNERAR15
Post by GUNNERAR15 »
my question is .I have my AG wash in 5 gallon buckets in my garage.What temp should i keep my garage at for my wash to work correctly...Its getting cold outside.....THANKS FOR THE HELP.
Hearts_On_Fire
Re: All grain wash question
Post by Hearts_On_Fire »
Depends on what temp your yeast requires. should be written on the yeast package. It's usually around 20 to 30 deg C, but you can go a bit above or below. Just make sure not too cold or your ferment won't start or will stall.
"Always carry a flagon of whiskey in case of snake bite, furthermore, always carry a small snake."
Durace11
Post by Durace11 »
Depends on the yeast strain, most yeasts will say on the packaging what the operating temperature is for best results. Bread yeast likes higher temps but beer and wine yeast like it a little lower. Also, in some yeasts higher temps can create off flavors so depending on what yeast you have the temps can still have a good ferment but give interesting and sometimes unwated results.
Current Evolution:
~ kekedog13
~Mr. P
GUNNERAR15
Thanks for the info.ill check the back of my yeast pack.....BE SAFE.
