My 2" boka
My 2" boka
well I'm tring to share my 2" boka I made over a year ago and post new pic. of my latest which is a 3" boka with a single coil condenser 13" long I made. If this gets up I'll post more. Oh by the way my 2" put's out 1.5 gal. with a 15 gal. wash @ about 170 abv.I hope the new 3" is more productive both ways.
Pork Fat Rules..now swallow..repeat..Drink..repeat..BBQ & Distilling = Slow and Low ......................done yeah baby!!!!!!
Re: My 2" boka
Very nice looking column...do you have plates where you have the site glasses? Also what kind of value are you using on that? I see a brass connector, so do you attach it to a small leibig?
Re: My 2" boka
The condenser 8" long is in the top section, as for plates I just use copper scrubs spaced apart about 3" each apart and there is a SS valve on the take off which finishs on an air coil.....finish temps around 75 degrees very easy to run.I will post my 3" column soon 4 foot 6" and a 13" copper coil condenser boka style. First run with water and tails produced just over pint in 15 min wide open...more later
Thanks ChefSteve
Thanks ChefSteve
Re: My 2" boka
Why does everbody need some high tech machine to produce good product? look make it simple enjoy your life spend a little enjoy life to the max just have fun
- Condensifier
Re: My 2" boka
+1 ChefSteveChefSteve wrote:Why does everbody need some high tech machine to produce good product? look make it simple enjoy your life spend a little enjoy life to the max just have fun
You do nice work. Thanks for sharing the pics with us.
