Mash smells good
jwconnelly
Mash smells good
Post by jwconnelly »
Well just started my first mash ever and so far so good. I did a lot of research prior to making it and used several different inputs to make mine. It has been fermenting for 5 days now and have all kinds of bubbles with it starting to clear at the top and settle to the bottom. Curiosity got the best of me so I popped the lid off my 7.5 gallon fermenter and took a look and man it smells good. Smells just like beer. I tried to take a reading with a hydrometer but haven't figured that out yet. Plan on running it in about 2 or 3 days and plan on using the stops bubbling and clear method to know when it is ready. I will let you guys know how it worked out. Below is the recipe I used.
5 gallons distilled water heated to 95 degrees
5 lbs flaked corn
8 lbs white sugar
4 packets of highly active yeast
TimJ
Re: Mash smells good
Post by TimJ »
You and I are at about the same place with our wash. I started UJSSM about the same time and will run it this weekend. Good luck with your run....keep us posted.
Tim
"It was a woman who drove me to drink -- and, you know, I never even thanked her.”
W.C. Fields
Durace11
Post by Durace11 »
Looking good, just keep the peeping to a minimum and you will be fine.
The hydrometer is fairly easy to use but you need a fairly clear ferment for it to work. You best bet is to wait until the surafec is clear of floating stuff then sanitize it and lower it slowly into the fermenter. Once it's in most of the way give it a twist to spin it. This will spin off the CO^2 bubbles so it will float at the proper height. As it slows down and stops bobbing up & down just read the markings on the side. Give it a few more spins if you have to to read it.
Current Evolution:
~ kekedog13
~Mr. P
condo33
Post by condo33 »
Durace11 wrote: give it a twist to spin it. This will spin off the CO^2 bubbles so it will float at the proper height. As it slows down and stops bobbing up & down just read the markings on the side. Give it a few more spins if you have to to read it.
This is a great little pearl of advice that I've never heard of before with reading hygrometers. And why this site is so very valuable. Thanks Durace11
Condo33
