![Very Happy :D](./images/smilies/icon_biggrin.gif)
![Cool 8)](./images/smilies/icon_cool.gif)
All soldered up and ready to go! I have run 2 batches through her, but not since I changed the length and the reflux assist. Will let you know how she runs.midnightmaraude wrote:That can't be soldered up yet? Can it? if so that is amazing work.
Run 2 batches through her, one mango wash and one peach. Going to run lychee wash through her tomorrow. First test with new reflux assistNcHooch wrote:Damn that's some clean work there Intrigue ...nothin like a shiny copper still .![]()
Have you tested it yet?
>>>CLICK HERE<<< for the instructions and "plans".NY Chris wrote:.....I know it's asking a lot, but if you get a chance could you post a sketch, nothing fancy, of the internals of your still.....Chris
The whole still is soldered together, there are no detachable parts, the only part not soldered is the column cap sothat the column can be cleaned. The still to the boiler has a gasket between. Any sugestions on how to get the outlet further from the heat source? I thought to maybe make a parrot. I might change the routing of the water to the column condensor and add vavles to have better control. After my run yesterday I couldn't get the column past 83deg c even although the gas was wide open. Thanks for your comments, support and knowledge.Richard7 wrote:I like the way intrigue swapped out the coils from the tutorial with a mini liebig. Although in the tutorial there are a lot of things that I have seen others here at HD do much safer. Mostly sealing parts with gasket and plastic tube.
check this out http://homedistiller.org/forum/viewtopi ... E#p6929617
Just a down hill copper tube is all I use to get to my parrot. I like the parrot but it is optional.
Its not going to get any hotter than the mix of alcohol and water will let it. Putting in more heat will only speed it up. If the temp does not sound right to ya (sorry I dont do metric) check your batteries, or get a good analog thermometer
Thanks for your comments, support and knowledge.![]()
Good luck!!!![]()
You could replace the 90 degree fitting at the top of the liebig with a copper union and 45 degree fitting so you could swivel the liebig to any angle you like, but then you would also have to replace the copper coolant piping with flexible hose to accommodate that adjustable movement.intrigue wrote:.....Any sugestions on how to get the outlet further from the heat source? .....
+1NY Chris wrote:Thanks for the link Soggy.
Chris
I used about a 3/4, 20l bucket of mangos, I have 2 mango orchards so I have plenty of mangos. I skinned the mangos and pitted them, I then added water and heated. Let it all cool down then sqashed through mutton cloth. The mango peel has a lot of oil in so I don't use them. I used 5kg of brown sugar, put 2.5kg with 5l of water with 1/4 tsp of tartic acid and brought to the boil and simmered for 10 minutes to invert sugar. After boiling I add 1Tblsp of Marmite(vegomite) as nutrient for yeast. I then do the same for the other 2.5kg of sugar. I then add ice to cool the wash down and topup with water to 20l. Reading on hydrometer should be about 1.090 - 1.100. I then take about 1lt of wash and start the yeast in that. I used plain brewers yeast that you buy from the supermarket for making ginger beer. We get it in 20g packs, I used 4 packs. When the wash is cool enough I pitch the hydrated yeast into the wash and seal the lid. I use a thick mix of flour and water to seal the lid and then add water to my airlock. Wash will ferment out to about 12 -13% alcohol in 6 - 8 days, reading on hydrometer will be 0.990. Calulation for % alcohol, first calculate drop in specific gravity 1.100 - 0.990 = 0.11, to get % 0.11 X 129 = 14.19. My wash fermented out to about 13%.maheel wrote:are you fermenting mango wash or just "flavoring" the wash ?
mango season here and i am thinking about some mango vodka etc....
thats some beautiful polishing !!!
Most of my mangos are the stringy type, got a few parafin and fish mango trees. I used the stringy type because they are very sweet but not nice to eat.maheel wrote:thanks for the mango info![]()
might have to go raid the tree down the road
i think they are "stringy" mangos not the nice eating ones but should go ok in a wash
