COOLING USING AN OLD AC COIL
dredyns
Post by dredyns »
Don't know if anyone on the forums have tried this but it seems to work on a first pass.
Took the outside portion of an old 4 ton AC unit.
I cut the freon lines away from the compressor and removed the compressor.
Added a 24vac transformer to actuate the relay/contactor to run the fan.
Fit some 3/8" tubing as a supply and return.
Ran the return from the outside condenser coils to a small ice chest (used as reservoir only)
Put a small submersible fountain pump in the Ice chest then ran a supply line to the "purifier"
Sent the heated affluent from the "purifier" back to the outside cooling coils.
Worked so well I had to turn the cooling fan off (65F outside) and throttle the supply a bit.
Anyone tried this?
Stainless dude
Re: COOLING USING AN OLD AC COIL
Post by Stainless dude »
I'm thinking of trying something like that, could you post a photo of your setup? I'm running city water now
But thinking about changing.
SD
wfw52
Post by wfw52 »
+ 2 on that post some pic's I wouls be interested in that also !!! great idea
thanks .....wfw
MexicanCustard
Post by MexicanCustard »
I use a reclaimed reheat coil from a VAV box. Same thing you have just smaller. I use a 35 gallon trash can as my reservoir and like you if the weather is cool I dont even have to run my box fan through it.
bellybuster
Post by bellybuster »
If they weren't so big I'd do this but just don't have the room. I need to come up wit something though
Maritimer
Post by Maritimer »
Here is my AC unit with some fans underneath:
http://homedistiller.org/forum/viewtopi ... 4#p7016292
M
dredyns
Post by dredyns »
Sorry I've been a bit busy (roof blew off). I will try and post a pic when I can.
