Forum for the discussion of any material/synthetics.Only posts with info /or links to research info allowed . Any posts recommend the use of any material without copy's or links to show proven research will be deleted
First stripping run yielded a clear, colourless distillate of 65%. I then added baking soda to it. The result is a colour change from clear, colourless to this opaque bluish colour. I assume that copper was present in the distillate in its ground state and then oxidized to copper salts (Cu2+). Does this happen to others?
Another good reason for carbon polishing even if your vodka smells neutral.
