Mash Temperature Control
Posted: Wed Mar 20, 2013 6:04 pm
by thegreenhundred
Hi,
I'm doing my first large ferment in a plastic 20 gal drum. I have done a 1 gal, and 5 gal before but those were done at room temps. The distillers yeast I am using now requires 30-35C.
My question is, what ways are there to maintain this temperature?
I have everything else operational except for a heated fermenter.
Re: Mash Temperature Control
Posted: Wed Mar 20, 2013 6:25 pm
by just-a-sip
do a search for mash temperature control... this will return many results containing ideas ranging from insulating the containers all the way down to light bulb heaters, heating pads, and even fish tank submersible heaters...
in the end there is more then one way to skin a cat
and since the yeast tend to do some warming of their own many of the ways are just to aid rather then fix a problem.
Posted: Wed Mar 20, 2013 6:55 pm
by mash rookie
The best method is to use a small room that you can temp control with a thermostat. An exhaust fan helps keep smell and bugs out. Using blankets, bulbs, aquarium heaters etc is always difficult if ambient temps fluxuate much. Consistent temps work well.
Posted: Wed Mar 20, 2013 7:42 pm
by sambedded
I just bought Water Pipe Heat Cable wrap it around fermenter and put some thermoinsulation on top of it (made from floor mats).
That cable includes a simple thermostat. I removed it and use a PID like this
http://www.aliexpress.com/item/RKC-Digi ... 55543.html" onclick="window.open(this.href);return false;" rel="nofollow to control a temperature.
Posted: Sat Mar 23, 2013 6:20 am
by zacwest52285
Aquarium heaters are fairly cheap. Mine will keep my 10 gal fermenter at 77 deg F.
http://www.walmart.com/ip/Tetra-Heater- ... s/10291809 This one should be perfect for you.
Posted: Sat Mar 23, 2013 6:35 am
by oliver90owner
35 is high. I have never seen one with that recommendation for fermentation temperature before; can you post a link or the supplier of this yeast, please?
Posted: Sat Mar 23, 2013 6:56 am
by Coyote
I have a 3' X 8' - 8' tall insulated fermenting room, Quick & cheap to build, heat it with a
1300 watt milk barn heater.
Works like a champ, when the ferment is done unplug the heater and let settle
rack it off, and run it.
Friend of mine uses the same thing except build of free standing foam board 4' x 8' 4' tall
3 sheets of foam board = $ 26 bucks, milk barn heater 16 bucks
Coyote
Posted: Sat Mar 23, 2013 9:46 am
by rad14701
I have a 2 x 4 x 4 foam board box that is disassembled and stored down in the barn that I used to use... Also have one in the pool building that is just big enough for a single carboy that uses a thermostat and shielded light bulb for heat... The pool building never goes below 50F... There is also a heated room in the barn that can be used... But most of my recent ferments have been done right in the kitchen... I have options...
Posted: Sat Mar 23, 2013 11:30 am
by MuleKicker
Aquarium heaters work good. Simple, and easy. I set one up in an old frige for insulation. Kept it warm in 0F temps.
