ok something went wrong
This is my first attempt on trying to make shine.
I Used Corn Meal, Sugar, yeast and water
I filled up a 1gallon milk jug with water a pored it into a pot and i added 2 cups of CM and i brought it to a boil then i added the 3 cups of sugar a stirred it all up and then i added the 2 packets of yeast.
I Then pored it all back in to the milk jug and i placed it in a cabinet. The next day i could see bubbles rising to the top with a foam layer on top of the liquid. 2 days later everything stopped bubbling i thought it was done. there was 2 layers in the milk jug a liquid layer and a solid layer that looked to me like grits.
i heard that you wanted the liquid layer so i siphoned off the liquid layer in to another milk jug and left the soild "grits".
My still is made up of a pressure cooker connected to a 4' copper tube going down to a copper coil submerged in ice.
after 15mins i started to get a steady drip i let the jar get half full of this clear liquid and i took a sip and it was water..
i say i filled up 1 and 1/2 jars full of water before i said duck it and pored it all out behind the shed.
what could have went wrong?
What I do is not boil the whole volume you intend to ferment. That way I top it up with cold water and can add some icecubes. If you have a thermomitor just make sure its below 40C then your ok to toss yeast in.
40c is for wine yeast im sure bakers yeast is similar but ive never used it. If you want to be safe aim for 35C. Make sure to stir before taking the temp as it may be hotter below than it is on the surface.
15 min is a short time. you either have a really small pressure cooker or to much heat. once you get your wash figured out heat the cooker with a moderate flame until you hear it boiling and then cut the heat down as low as you can and still here a soft simmer. when using a closed boiler and condender like you are you cold stand the risk of an explosion. remember that the pressure cooker is designed for about 10lbs of pressure. if you keep the heat real low you should be safe and the shine should be better. do some more reading on this sight and the parent site and good luck.
Day Late;Dollar Short
Tater,
You are embarrassing these poor youngsters. They will be in our shoes someday, and hopefully correcting other youngsters. We have to teach them with a loveing paddle, or a pack of matches, or preferrably just plain good advise, so they will learn and pass it on.
We were both that age once, and impatiant, hopefully, we can give them our aquired wisdom, if they want to hear. I'm an oldster, but still learning much from you!
> "You are what you repeatedly do. Excellence is not an event - it is a
>habit" Aristotle
>habit" Aristotle
This statement was why I asked . Read over sights in my signature.. .Distilling will make lot more sence to ya then.Do this and you will find fokes doing best to help you out.Welcome to fourmMrShineOn wrote:That's another thing i did wrong was, i had the heat on HIGH.
Also the pressure cooker I'm using has a safety feature built in when the pressure gets to high it will pop open a valve like and release some of the pressure.
I didn't see anyone tell you to aerate the wash before adding the yeast. Do it - yeasties like a bit of oxygen to get them breeding up before the have to settle down to working for you.
In this case - pleasure before work - but maybe they're married and breeding is less pleasurable than making whisky.
know read some more and you will have some good shine. i have been doing this off and on for about six years and after my last batch i concider everything before it crap. i have finally gotten an idea of how to make my cuts. lots of people just lurk and learn. its not a bad idea. once you learn the basics then when you ask a question you will most likely get some good advice. congrats on your success but i guarentee that it will get better with time and practice. good luck.
