Potentiometer no worky
Posted: Fri Apr 26, 2013 2:16 am
by Mustachio
My relay and potentiometer are not functioning correctly. When I move the knob, the voltage doesn't change. It has 120 going into the relay, and 115 coming out.
I'm using a clarostat 25 k linear pot RV4NAYSD253A, and a Crydon A4850 SSR.
Re: Potentiometer no worky
Posted: Fri Apr 26, 2013 2:47 am
by Mustachio
here is a pic
Posted: Fri Apr 26, 2013 3:26 am
by bellybuster
The 48 series SSR is a voltage input SSR. The 4850 is the 50amp version. It will not work. You need a resistance input SSR
Posted: Fri Apr 26, 2013 6:12 am
by rad14701
bellybuster wrote:The 48 series SSR is a voltage input SSR. The 4850 is the 50amp version. It will not work. You need a resistance input SSR
+1
That unit requires AC voltage on the trigger side, not a potentiometer... You can either spend money on the proper control circuit (not recommended) or purchase the correct SSR (recommended)...
Posted: Wed May 01, 2013 2:29 pm
by Mustachio
I purchased a different relay, one I seen someone said would work on this forum. Still not working
KYOTTO AC Solid State Variable Relay
Part No. : KR2075AX
All it seems to do is knock 25 volts off.
Posted: Wed May 01, 2013 2:35 pm
by Mustachio
http://www.ebay.com/itm/140553987088?ss ... 1438.l2649" onclick="window.open(this.href);return false;" rel="nofollow
Posted: Thu May 02, 2013 2:25 am
by Mustachio
Think I just figured it out. Does one of the prongs on the pot need to be grounded, or wired to one of the other prongs?
Posted: Thu May 02, 2013 4:15 am
by bellybuster
No, either the left or right prong stays open. Which ever side you hook to is the direction of turn for the pot. The other wire goes to the centre prong.
What is the resistance on your pot? Did you use the one that came with the SSR? Cheap Chinese pots are usually pretty good but I've had a few bad ones repairing guitars.
Give us a rough schematic of your hookup.
Posted: Thu May 02, 2013 7:04 am
by bellybuster
here's a very basic schematic on how to hook up the pot. Everything needs to be grounded, case included, the pot itself not so much but I ground mine anyways with a lug under the washer that tightens it on.
Posted: Thu May 02, 2013 7:53 am
by Mustachio
Thats how it has been wired up, and I tried two different pots. So I was wondering if Ishould do it like this one.
http://homedistiller.org/forum/viewtopi ... start=1272
Posted: Thu May 02, 2013 7:56 am
by bellybuster
well it's one of two things, the pot or the SSR. have you metered the pot to ensure it's 500k?
Posted: Thu May 02, 2013 8:19 am
by Mustachio
I'll have to check when I get off work.
Posted: Thu May 02, 2013 4:07 pm
by Mustachio
I grounded the unused post off the pot and it works, I guess. The voltage would fluctuate, but was not very stable/consistent.
