Here is a drawing I just made for my new still plan. (not strictly to scale)
Right now it's just the 5 gal milk can with 1" pipe coming off original lid and to a flake stand (3/8") at a 45 degree angle. It's served me well for around 10 runs this past 6 months but its time for an upgrade.
My new plan is to ditch the original lid, fix a mixing bowl on top which will have a 2" tri-clamp ferrule welded on top. Also a thumper is added in this plan. As you can see, the plan utilizes 4 tri-clamps with 5 EZ flanges and 3 SS ferrules. The reason behind that is for facile breaking down and transporting.
Please feel free to critique constructively and offer suggestions. Right now I'm thinking the condenser will be 12-14" long, shotgun style, with 4 3/8" tubes inside that I might try to give a bit of a twist so that there will be more than 4 times the length of the outer casing of distillate path inside the condenser. The reason I want a shotgun is because it is more compact than a liebig but if you can suggest something better go right ahead!
Also it's design is such that eventually, when I have room, I can turn the milk can into the thumper for a keg boiler and keep most of the original tubing.
Additionally it will be powered by a 1500 watt element (already installed). I don't have 220v access right now for anything more powerful.
My upgraded still
My upgraded still
Away with yer pills, it'll cure all ills, Be ye Pagan, Christian or Jew,
so take off your coat and grease your throat with a bucketful of Mountain Dew.
Re: My upgraded still
Looks great, I want to add a thumper to mine. Don't forget a vent above your parrot
I assume because of the mention of 2" ferrules you intend to use 2" pipe. Seems like big pipe for such a small set up. I would stick with the 1" because I would rather have faster vapour velocities into my thumper to transfer as much heat as possible. You will find the heat input needed to run a thumper is quite a bit more then just a pot still. Besides the pipe its the same size as my old set up which served me well for years.
Yes I intend to use 2" piping throughout. I agree that it may be a bit too large but I plan on using the same set of pipes when I eventually upgrade to a keg boiler so that's why I want to use 2".
