So to calculate how much I need to dilute my distillate to provide a lower % of alc. I use this formula:
(amount of distillate)x(% of distilliate)= (amount of 100% alc. in sample)
(amount of 100% alc. in sample) / (desired % of alc.) = (amount of distillate at that % which will be left after dilution)
(amount of diluted spirit) - (original amoutn of alc.) = (How much water needs to be added to dilute original sample)
ex. (750ml) x (.70%) = (525ml) / (.40%) = (1312.5ml) - (750ml) = (562.5ml)
How do you figure out the % of alc. after dilution.
ex. If I were to add 2 bottles of sprite* to 1 bottle of everclear and then add 1lb of sugar.
Mathematic equations (help)
If it dont burn it aint good!
Proudly tearing up the blacktop since 1996!
I ended up making a spread sheet.
Try this: http://members.iinet.net.au/~shanej/Alc ... 0Table.xls" onclick="window.open(this.href);return false;" rel="nofollow
Here froggy froggy..
Shane
Our reading material:
The Compleat Distiller
Making Pure Corn Whiskey
Shane
just remember that volumes are not additive. ie. 1L alcohol + 1L water doesn't equal 2L. To get around this you measure the initial volume of alcohol and its strength, then measure the final volume of the liquids combined instead of volume of liquid added. The simple equation is a ratio
initialABV*volume=finalABV*finalvolume
rearranged
finalvolume
rearranged
finalvolume
