How long should I soak the barrel? I filled it with spring water and have it immersed in water now. 36 hours enough?
(5 Gallon charred barrel)
No instructions came with My Gibbs barrel
- Location: Deep in the woods up in the holler on Greasy Creek
Fill them. Let soak a day or two. On some you will see seapage. Judge by the seapage or lack of it. You will however save alcohol with a little longer soak to fill the wood. The variation in seepage to a small degree depends on if it has been sitting in the warehouse long. I still see a small amount in one of three on a hot day whem pressure builds up. Not enough to worr about.
